supercarrera82's Avatar
wheel spacer question...how will the original bolts not get in the way
I am planning on buying 1" spacers for the rear end of the car but i was thinking ofsomething that didnt make sense , im pretty sure the original wheel bolts on the car are longer than 1", so when I put the spacers on, wont the orginal bolts come out farther than the spacer ?? and that way the rim wont sit flush on the new spacers, instead wont it sit on the excess bolts???? Maybe im way off here, do i cut them (i doubt it)???? Ne one experience this, thanks. Arvin
Old 07-16-2007, 11:23 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
If you put spacers....you need to re-install new studs...if you go with adapters...you keep the originals ones...
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 07-16-2007, 12:07 PM
"O"man(are we in trouble)
widgeon13's Avatar
You need to measure the studs that are on the car now and see how long they are. The original studs on a 911 were 45mm I believe, that includes the entire length fro the head on the back of the disk. If they are longer than that, more than likely they will not work with adapters but could work w/ spacers.
Old 07-16-2007, 12:20 PM
Throw it on the ground!
Re: wheel spacer question...how will the original bolts not get in the way
All of your questions should be answered here!
Wheel Stud replacement...A pictoral..
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 07-16-2007, 12:40 PM
ttweed's Avatar
Re: Re: wheel spacer question...how will the original bolts not get in the way
Actually, that thread answers questions about installing longer studs to use spacers. Arvin's question is about studded adapters, and I think it is answered in this thread.
There is a hollow in Fuchs and other OEM Porsche wheels that will allow the wheel to be mounted without interfering with the 1/4" or so of protruding stud you will have using 1" adapters. Some aftermarket wheels will NOT have this hollow area, though.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 07-18-2007, 02:03 PM
