tbitz's Avatar
Cold start problems? What cold start problems?
I looked and looked in my engine bay and can't find any WUR, thermo-time valve, enrichement screws
Tony
'78 911SC with BITZRACING EFI conversion kit
Old 04-06-2005, 11:26 AM
Somewhere in the Midwest
MotoSook's Avatar
CIS Hater
Old 04-06-2005, 11:28 AM
Virginia Rocks!
VaSteve's Avatar
This thread needs a way to have it automatically reappear each season.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 04-06-2005, 12:50 PM
Oh Haha's Avatar
This is funny. I just went out and turned the 3mm screw a click back form the cold weather setting. I must be getting to know this CIS system now.
Pacific Blue
Wayne
Old 04-06-2005, 01:35 PM
Hopelessly Addicted
Porschephanatic's Avatar
Question
Are the PMO's any less sensitive to changes in atmospheric conditions? I've been considering switching to these for some time now. CIS works fine, now, until it's warm and sits for ten minutes, then on restart it won't idle right for a while unless I run it holding the accelerator for 2 minutes or so. EFI vs. CIS vs. PMO?
'81 SC Targa
'86 944
'49 Ford F-3
'13 Yamaha FZ-1 (Adrenaline Machine)
Old 04-13-2005, 05:25 AM
We can't let the thred slip down the page!
I'm trouble shooting my CIS and this is valueable info.
I'm gonna print this thred so keep it coming.
I wish there was a pelican in RI that could take a look at it before I destroy my air box. If I have'nt already
My car runs great after warm up. But cold starts require some skill. It starts right away then stumbles and dies. I have to do this about four times before it finally catches. I have to do it just right to avoid backfiring.
I think I'm too lean because my exhaust is very clean. Can't even smell exaust fumes very much. but it don't know for sure.
I'm gonna poke around with my acetyline for vacume leaks.
I just had the engine rebuilt and all the intake boots look good. I did have a sizeable backfire so I'm gonna check around the box also.
Pop off valve works fine but I don't know if it could take the backfire I had. Then again it happened in the garage so it was pretty load.
I guess the first thing I'll try is to richen the mixture a bit before I start it up cold and see if there is any improvement.
Any other ideas?
Silver 1980SC Euro coupe
Old 04-13-2005, 07:25 AM
MotoSook's Avatar
Brian, your cold start/running needs adjustment. PMO's are going to be expensive and you'll still have to deal with the cold starting on spring or fall mornings...unless the PMO's have a choke now.
Think of the CIS as a sophisticated carb...and your cold running conditions are a poorly adjusted choke circuit. There is not one thing that can be pointed at as the problem. Sounds like you just need a good tune up and analysis.
Ron...you need a good tune up and analysis too. Sounds like you have more air than you need on startup...could be lean setting or could be a leak of the AAV or AAR...or some other. Have you checked your fuel pressures?
Old 04-13-2005, 07:33 AM
We checked the fuel presures when the engine was put in.
I think they were 50psi cold and when warm around 30 psi.
We also tried another fuel pump for another un-related problem.
Old 04-13-2005, 07:46 AM
MotoSook's Avatar
It should be the other way around. lower pressure cold, higher warm. What were your system and residual pressures?
From your description, try richening the mixture a bit and you might start easier.
Old 04-13-2005, 07:50 AM
Will do and thanks. I'm gonna get a gauge and go all through it. I'll let you know what I have for presures for sure.
It could be the other way around cause I was just enjoying the sound of my newly rebuilt engine being brought back to life . I brought the engine to a great wrench in boxes
Old 04-13-2005, 08:16 AM
souk funny you should mention this I just ordered a cis pressure tester and borrowed the 4 gas anaylizer from work . My car starts fine any time just when it warms up it runs a tad lean. I will get it up and running properly shortly.. Hey did you say you rebuild these WUR?? You have me interested
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 04-13-2005, 08:22 AM
Virginia Rocks!
VaSteve's Avatar
Bump. A couple of days early.
Old 09-30-2005, 11:32 AM
Gon fix it with me hammer
svandamme's Avatar
mwah , i have my gear (on the 924)wired up to a button on my dash
full control, and no hot start issues either, and no worries bout worn out thermotime switches or what not
and most of the time , i don't even touch that button , it just starts without
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-30-2005, 11:49 AM
K9Torro's Avatar
Souk - funny you should bring this up, my newly rebuilt engine in my 79SC 3.0L never has a problem starting with just a bump of the starter when warm/hot outside , or when the engine itself is warm/hot regardless of temp.
But our temps have just started to drop they are in the 40's at night now here in South GA and sure enough I am having a real problem with cold starts,
The engine trys to start but dies right away, I go through this for no kidding about 20 tries before it catches and then stumbles until it warms up, my exhaust smells like it it plenty rich.
I am leaning toward a bad WUR, it is the factory original one and looks it from the outside, I belive the cold start valve is working.
I found a company that sells rebuilt ones for $235 an I am thinking about getting one put on.
Todd
Old 10-27-2005, 04:54 PM
ianc's Avatar
K9, sounds like a cold control pressure problem. Instead of spending $235 for a rebuilt WUR (which is a gamble), spend $75 on a pressure gauge and check it out. For an afternoon's labor, you can make your WUR adjustable, then you can set it exactly as it should be.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 10-27-2005, 09:52 PM
randywebb's Avatar
Gawd no don't think of the CIS as a sophisticated carb.
I'll admit it is better for cold starts (unless it blows up - but hey what's a big hole in a thousand dollar bill, anyway). But why buy a sports car that has the engine responsiveness of a tractor?
Of course, I'm a confirmed CIS-hater....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-27-2005, 10:07 PM
ianc's Avatar
Randy Randy Randy,
In every way except instantaneous throttle response and ultimate high-RPM horsepower (NOT torque), the CIS is far and away superior to any carbs made. The world has moved on from 1965 for a reason,
ianc
Old 10-27-2005, 10:24 PM
randywebb's Avatar
I agree. But the world also moved on from 1975... so just jump to EFI...
Old 10-27-2005, 10:25 PM
MotoSook's Avatar
Todd,
I wouldn't be so quick to swap out the WUR. Like Ianc said, get a pressure tester before you spend any more money. Does the car smell rich all the time? Or just during start up? You can be overly rich too. Sure the air is cooler, and one may think it should lean out. However, there are other things affected by the temps. The AAR and WUR are now slower to go to normal operations.
I would get the car running, then after it warms up (go drive it around) and check the idle mixture. Look for my thread on the "field adjustment" for the idle mixture.
Randy, throttle response difference is over rated. And the difference is hardly justification to swap out a perfectly good induction system. I've driven carburated cars, EFI cars, MFI cars and CIS cars. There is little I'm missing with my CIS car. Throttle response counts for naught when you mash the throttle at 3000 RPM or less. Anything I'm missing with my CIS car, I make up in shifting and drivng behavior. Put it in the power band and go!!!!!!!
Edit: Todd this thread is just over a year old
Old 10-28-2005, 05:04 AM
K9Torro's Avatar
Souk -
Can you recommend a pressure tester set up and where to get it from ?
Thanks,
Todd
Old 10-28-2005, 06:21 AM
