Thank you for all the info, Gentlemen. Think I'll buy the pressure gauge and books on Bosch fuel injection. Which one is the best? Edit: [Maybe covers my 944, too?]
Wayne sells a tester:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait= N&make=POR&model=911L§ion=TOLtol&page=5&bookma rk=26&part_number=PEL-PP910450 As for a manual that covers CIS and DME...not on book is good enough for either in my opinion. I have a number of manuals that when put together would be adequate. As a start, I would recommend the Bentley manual. It's not perfect but it is good for CIS and other aspects of your 911 maintenance. Jim Williams his a great CIS primer...someone will come allong and post a link if I don't find it first...or you can search for his posts, and follow his link. There are also other online sites good for learning CIS, some even have good downloadable PDF's. One of these days, I'll write a book on CIS that pulls together all the available information....but that day will probably come when I retire...then there'll only be just a handfull of CIS 911's still running :( :D |
Haha, don't be so sure, Souk.
I've been adjusting CIS cars since 1977. Look how many are still around today. With the care people on this BB lavish on these cars I wouldn't be surprised to see quite a few still around for quite a few years, as long as we can still get gas for them! With a trusty 3mm allen, an occasional check for vacuum leaks, and a pressure gauge (optional-I just got my first one this year), along w/ the valuable info on this board, these cars should run for a good long time. Just remember: spring/lean, fall/rich for those of us in northern climes. Usually no more than 1/8 turn is all it takes. |
Maybe so Paul....rather I hope so :) Not that I think CIS is the only induction system out there, nor the best, but I like simple things that work well...simple for you and me :)
OK! Here is a collection of information that should be helpful: CIS Diagram: http://www.pelicanparts.com/911/911_...8-83/1-7-2.JPG Mixture Adjustment w/o an analyzer: http://forums.pelicanparts.com/porsche-911-technical-forum/232089-cis-idle-speed-mixture-setting-without-analyzer.html?highlight=cis Jim Williams' CIS Primer: http://members.rennlist.com/jimwms/CIS/CIShome.html CIS cut-away: http://forums.pelicanparts.com/uploa...1130510551.jpg |
Where did the CIS cutaway come from? I would like to get a copy large enough to read the print.
This Temperate Climate CIS thread should live on forever.
I know I'll read and probably post again in spring -- right here! |
Although I agree with Souk; the CIS is not the best induction system out there by far, but I like simple dependable things that work. And Souk, that is a cool cutaway! Another vote for a larger version if you have one? ianc |
I did not create that picture, and I can't vouch for the text on it...(Edit: I should also add that the cut-away is not that of a Porsche 911 system, but it's close.)
It was posted in this thread (I don't know if Dr. Injection even posts here anymore. He never got back to me on the manual request :( ) http://forums.pelicanparts.com/porsche-911-technical-forum/164209-cis-metering-unit.html http://home.broadpark.no/~alejoha/kjetronic22.jpg |
How timely is this post. I got in my car this morning, temp 30 deg F
Turned it over . Bang! tried it again. It would start and die, start and die. I pulled the air cleaner off and pushed the control arm up. I do this when it runs rough. The pop-off valve was completely blown off. I started it and the tach pegged. Not good. Took the other car to work. I believe this is all cold weather related. What caused the engine to rev so high? Is there somethind else that would cause this? It's going to be 65 tomorrow. The SC loves that temp. |
You're bypassing the throttle (pop-off valve blow off right?), and there is enough fuel fed to the engine via the cold start sequence and your priming of the engine...so you essentially had an un-governed engine at that point....
...clean and prep as appropriate and reinstall the pop-off valve, richen the idle mixture a bit (1/8th turn to start with...). If that doesn't work...check for cracks in the airbox (cross your fingers). Good luck. |
Souk,
Did I "break" something? Where would the cracks be? |
Busted something as in pistons or valves?
bump
Don't worry Limble, you didn't damage anything majorly expensive. You will need to reinstall your popoff valve though,
ianc |
I've got a question:
In the CIS diagram above there is a hose labeled 16 that attaches to part 54. On my '80 SC hose 16 is missing and the nipple on part 54 is exposed to free air. What does hose 16 and part 54 do? From the looks of the diagram something on my CIS system is missing and possibly causing a vaccum leak. -Scott |
Hmm....I think I answered my own question. According to the CIS primer that nipple is exposed to atmosphere on '78-'79 and '81-'83 models. Somewhat strange though since my car is an '80.
http://members.rennlist.com/jimwms/CIS/WUR_photo.html |
Hi Kaefer,
17a (which hose 16 connects to) looks like an altitude compensating device to me. I would try to locate 17a and see if the hose is plugged or not. It may also be that the WUR (#54) has been replaced on your car and the original did not have it. ianc |
That's one of the things that make Porsches like a rubic's cube: they made small changes just about every year to the CIS.
The hose you are talking about it a vaccum line to the warm up regulator #54 (control pressure regulator is the correct name). On a 1980 US SC you don't have one, I don't either. On some earlier years they had one, and on some later years they had one, but on a 1980 they didn't. Thje decel valve (#7) is different also. |
I saw this a while back and was saving it for a thread like this:
The world is divided into three types of CIS Owners, which one is you? 1) The guys with working CIS systems out driving their cars so they won't reply. 2) The guys that tinker with their CIS systems and have them royally screwed up and keep you running in circles with suggestions. 3) The guys that have spent a fortune on Webers, PMOs, EFI etc will tell you they're great to justify their expenditure to themselves. Your choice. ;) |
| All times are GMT -8. The time now is 12:59 PM. |
