-   -   It's that time of the year AGAIN! (CIS) (http://forums.pelicanparts.com/porsche-911-technical-forum/185926-its-time-year-again-cis.html)
MotoSook 10-06-2004 10:44 AM
Get ready for the CIS start-up questions to come rolling in.
It's discussed every year in the spring and in the fall....
What happens during this time of year? Take a guess...go ahead...
mtelliott 10-06-2004 10:56 AM
I'm new here so clue me in. Are you suggesting that people begin to have problems with their CIS in the fall/winter? Is so, I'm guessing it's WUR related?
MotoSook 10-06-2004 10:58 AM
That's a part of it....why?
mtelliott 10-06-2004 11:01 AM
Cold Start Valve would be the other part. Colder temperature being the likely cause. But, I have a feeling this is a little more technical of a question?
RickM 10-06-2004 11:16 AM
Extended temperature changes make things expand, crack, stretch, shrink & corrode. I've observed the same phenomena during the seasonal changes as well.
MotoSook 10-06-2004 11:29 AM
Yes! The ambient conditions are changing! The CIS sub-components, such as the WUR and the AAR are being affected and they will start to work differently now that that the morning temps are so low. What was fine when the morning temperature was 70 is now not so good at 40 degrees. Some of you are lucky and your WUR or AAR are not so finicky. I have heard reports of finicky CIS engines when they were new from their original owners. It's unreasonable to expect our 20+ yr old cars to be consistent over the wide temperature range.
Think sticky AAR valves, stiffer WUR springs and system pressure spring, harden diaphragms, vacuum leaks, internal air leak, etc,..
Some of the later CIS cars (80-83) with the Lambda circuit should be able to compensate better. But even those cars have a limit to how well the frequency valve can help.
So don’t start fooling around with the CIS components, when all you need to do is richen up the idle mixture. Why richen? The cold air is more dense, so if your CIS was set up to idle well cold during summer months, with the idle mixture on the lean side…what happens now? It’ll be too lean to idle well. Crap our CIS engines love to be rich, right? Denser cold air is nothing new and shouldn’t shock anyone, but when our cars start to act up, the whole Porsche wrenching mystique gets us thinking the worst….
RickM 10-06-2004 11:33 AM
Colder air is usually drier too. I'm sure humidity and the state it's in (liquid or solid) have an effect as well.
evill 10-06-2004 11:37 AM
Funny, I just gave my mixture screw a little tweak this morning (richer). It fired right up into a nice idle. Also eliminated the lean surge it had yesterday.
It's getting cold here in NJ, but my 3-mm allen wrench was ready for it.
Ed
MotoSook 10-06-2004 11:47 AM
Right on, Rick.
I should also say that my "leaner" example above is not to be taken for granted as the only possibility. As the spring in the WUR and the diaphragm age, the WUR can cause a rich or lean idle condition. If the AAR takes longer to close because the crud in it is making the vane sticky, but the WUR is working good...then it may lean as the engine warms...
There are several combinations of things that will cause those small hassles, but the thing to keep in mind is the ambient conditions!
Tim Hancock 10-06-2004 12:45 PM
Hey Souk are you a CIS expert? My recently acquired 79 SC is nearing installation of it's engine that I just did a top o'haul on. While cleaning up the CIS system I noticed that it has a newer WUR (with a rebuilt sticker on it) that does not have vacuum ports on it. After searching I have concluded that it is a newer post '79 WUR. The newer cars used an O2 sensor to enrich the mixture during acceleration. Do I run the risk of engine damage if I drive the car w/ out the proper WUR? Can I assume that the acceleration will not be as good as it should be?
I posted a thread on this a couple days ago and no one that responded seemed to know whether or not this is a big deal.
Just fishin for suggestions.
I will buy a new WUR if neccesary. But I would at least like to start this thing up this weekend.
MotoSook 10-06-2004 01:08 PM
Tim,
In a pinch I installed an 82 WUR on my 78 engine. I've got the idle mixture turned to rich, and I'm running 32 degrees total advance. With all the projects I have going on, I have not rebuilt the two 78-79 WUR that I have on the shelf. So my car has been running with the non-stock WUR for a long time. I've even driven the piss out of it at the track. The engine temperature was not unusual so I assume that my set up is fine. CHT readings would help me, but I'm not worried about it. And for just the weekend....don't worry about it.
My engine runs strong, cool and accelerates just fine.
MotoSook 10-06-2004 01:10 PM
Nope! I slept at a Holiday Inn Express last night :)
911SCfanatic 10-06-2004 01:13 PM
...and you probably did, too :D
MotoSook 10-06-2004 01:14 PM
Not recently Bill, but I'm to be back on the road in a couple weeks :( and not in your area :(
tsuter 10-06-2004 04:16 PM
Re: It's that time of the year AGAIN! (CIS)
Souk,
I hear you can set mixture without a fancy pants gas analyzer just by bending over and sniffing the exhaust gases.
Are you going to demonstrate this before or after the cart race Sunday?
jlandreth 10-06-2004 04:27 PM
I'm in Ohio and mine starts and runs fine
tdatk 10-06-2004 04:31 PM
n00b question,
SO where is this mixture adjustment screw exactly.? Pic please.
Tim
MotoSook 10-06-2004 04:39 PM
Suter: My nose is out of calibration :) But if you want, I can tune that beast of yours in trade for a drive :D
jlandeth: you are one of the lucky ones. I don't usually have to fiddle with mine, but I know when it changes. There are more cases of the lucky ones than there are the unlucky ones.
Tim: If you search "idle mixture screw" you will find a lot of pictures. Some of which I posted for "n00b's" such as yourself :) If you do find it, link it to this thread...or I'll do it later....later later.
Porschephanatic 10-06-2004 04:46 PM
Mine is running better now in this colder weather. Must have been too rich all summer long.
tdatk 10-06-2004 05:04 PM
This is the only pic I could find. I will do a hands on and post a bigger one.
link
tsuter 10-06-2004 05:10 PM
OK Maybe, Have you driven cstreits 930? I want a little butt dyno comparison and I was thinking of letting him take it out.
To keep this OT, maybe a parking lot class in finding the CIS mixture adjusting hole for the newbs?
How would you set if it the car isn't idling anyway??? Jeeeez!! :)
This may all be idle talk (hahaha), I gotta get through immigration Friday or Sat or I won't be there......
Thack 10-06-2004 05:54 PM
Tim,
You can damage your engine with the non-vacuum WUR. The vacuum works at full throttle and helps richen the mixture by lowering the control pressure. It has a diaphragm that pulls on one of two springs so the upper diaphragm lets more fuel flow, thus lowering control pressure. In the 80-83 year models the freq. valve adjusts the mixture at full throttle.
Mike
MotoSook 10-06-2004 06:20 PM
Mike,
I ran my car for a long time w/o any issues, no pinging (even with 32 degrees total advance) and no hot running. I know how the WUR works, but I don't know how much more rich the vaccum makes it. Do you? Anyone have an LM-1 they'd like to loan me?
And the mismatched WUR has no problems giving me a rich mixture...just ask some of the people that have seen the flame balls out my tail pipe.
on-ramp 10-06-2004 06:24 PM
start-up is normal....drive 10 min to the grocery store, get back in , re-start, idles crazy at 2,000 RPMS!!!
every fall, winter same.
MotoSook 10-06-2004 06:26 PM
on-ramp...have you ever cleaned you AAR?
MotoSook 10-06-2004 06:28 PM
Here nOObs ":
http://forums.pelicanparts.com/uploa...1097112489.jpg
http://forums.pelicanparts.com/uploa...1097112520.jpg
on-ramp 10-06-2004 06:32 PM
what does that look like? and where is it?
MotoSook 10-06-2004 06:37 PM
I'm just guessing why you ramp up to 2000...
But here is the AAR: (#36)
http://forums.pelicanparts.com/uploa...1097113040.jpg
MotoSook 10-06-2004 06:49 PM
A little more info in this thread regarding mixture and that O2 sensor.
http://forums.pelicanparts.com/porsche-911-technical-forum/137062-why-disconnect-o2-sensor.html
tdatk 10-06-2004 06:53 PM
Thanks Souk,
rt click copy paste.....save as "what I learned today"
; 0
Thack 10-06-2004 07:18 PM
Souk,
You can put a CIS pressure tester in line with the WUR and then put a vacuum puller on the correct vacuum line on the WUR. I'm not sure what values are achieved. I put on one of these earlier vacuum WURs on my non-vacuum car and I had to adjust my mixture because I heard some pinging. Just wanted to tell Tim to be careful. It would be interesting to put an air-fuel ratio meter in your car and see what happpens at full throttle. It would be interesting to see what happens in the O2 lambda car also.
Mike
mr.bch 10-06-2004 07:30 PM
I feel lucky. Just like last year, my 81SC started just fine this week and idled with only a little hunting. I am here in MI where the temps on Monday were IN THE 20s! There are so many CIS topics on this board, I think when I start having probs, I will just convert to EFI than trying to sort through them all :D
cantdrv55 10-06-2004 08:25 PM
Souk, it's like you read my mind or something. I live in Northern CA at sea level and last night I spent the night in Reno, NV (not at a Holiday Inn Express). My car would die at start up and at every stop light even when it reached operating temp. I knew it had something to do with mixture but couldn't understand why I suddenly had to mess with it when my car runs fine back home. I thought the thinner air in Reno was causing my car to run leaner than normal. I guess that did contribute but mostly because it's way cooler there in the AM and drier as well. Thanks for the timely thread!
MotoSook 10-06-2004 08:45 PM
Mike,
I'm working on some alternative inductions so an LM-1 is in my future for testing. It'll be a fun experiement; however, with the range of control pressure that the CIS can run with, the variability in WUR final pressure and the variability of idle mixture setting, I'm not too worried about lean issues. A day at the track didn't reveal any issues with my advanced timing, 89 octane fuel and idle mixture setting. I'll post the results of my testing.
Chris,
The CIS has some adjustability for altitude, buyt just like for temps..it's not enough. Glad you got soemthing out of this thread.
Tim Hancock 10-07-2004 04:47 AM
Thanks Souk and Thack!
Thack, I understand the concept of how the WUR on a 79 is supposed to enrichen the mixture when there is no vacuum due to tromping the pedal to accelerate. That is why I asked about a risk of damage running with the non vacuum WUR. I will proceed with caution.
Souk, you have proven with your similar set-up that damage is not likely. I will do a thorough check of all my CIS components at initial startup and I will probably set the mixture a little rich just to be safe.
thanks again guys!
Paulporsche 10-07-2004 05:40 AM
Tim,
I've found that setting the mixture so it is just shy of the point where the idle starts to hunt when warm suits my engine best.
Also, as I mentioned in your earlier post, while I never experienced any damage that I know of during the short time I had the non vac WUR, switching to the vac style helped w/ start & warmup. My gas mileage also seems to be better.
MotoSook 10-07-2004 05:46 AM
Thermo-time valve helped your start up and warm up. (I tossed mine a long time ago) ... and you got better mileage because you can get a way with running leaner and letting the vacuum richen it up when you needed it .. but that's from a lean setting...from a rich...who cares...I blow flame balls easy enough.
Tim Hancock 10-07-2004 05:46 AM
Thanks Paul, It makes perfect sense that a properly setup system will perform better and also get better gas mileage. I will temporarily need to compromise fuel mileage with a slightly richer o'all mixture until I can get the proper set-up.
Paulporsche 10-07-2004 06:05 AM
"I blow flame balls easy enough" -Soukhttp://www.pelicanparts.com/support/...s/beerchug.gif
BTW I have a non vac WUR (1980 an up) w/ only about 3000 mi on it if anyone needs one.
MotoSook 04-06-2005 10:01 AM
Here we go again! One more season.
Start-up and all the good CIS mystery starting to show up yet again.
