I know this has got to be the most retarded question ever, but where do you fill the window washer fluid? I looked all over but couldn't find it...
Alan Jackson 77 911S 3.2 |
Friend of Warren
Look inside the gas filler flap on later models. Early models had the bottle at the drivers side front accessed from inside the trunk.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Here's a related question...
How do you drain the window washer fluid? Do you have to just pump it out via the washer pump? Or, is there a better way?Thanks!
1972 911T 1972 911E "RSR" |
I think there is a line from the washer fluid tank to the pump that runs along the inside of the front left fender to the pump...just disconnect the line from either end and have a container ready.
Marc Morrison 1964 356C coupe '89 911 coupe 2008 Honda Accord 2008 Ford Ranger |
