2.4T lack of power? or normal?
I recently registered my first 911 last week. I've been working on it for months to get it to this point. The car is a '74 coupe with a '73T motor that someone swapped in at some point. I am very pleased with how the car starts, idles, runs. Smooth & consistent. But the car has no get up & go! I can put the pedal to the floor & the car goes, but with no authority whatsoever. (My stock '92 VW GLi is quite a bit quicker) Is this what I should expect from this motor? Is it known for kinda being a dog? If thats the case, then I'll just live with it for now. The only engine items that I've looked at thus far, I installed Bursch headers & muffler, adjusted the valves & changed to NGK plugs. Plug gap is to spec & the points were replaced prior to my purchase. I also run a manual thermostat mod as suggested by Grady. As I mentioned, the thing runs very well, just no get-up & go. Open to suggestions: -John
'73 RS Clone (flared, lowered, backdated, swapped) '72 124 Spider (newest project; shaved & lowered cruiser) '97 328ic (wife's toy) '05 3500HD D/A (tow vehicle) |
Bandwidth AbUser
Toast, it's only about 140hp, so I wouldn't expect the T engine to set your hair on fire. Does your engine have MFI, carbs or CIS? You might be able to tune it a bit for more performance.
Jim R. |
Have you gone through check, measure, adjust? I was plesantly suprised by my 140 HP T motor, but then again I wasn't expecting much with a dead hole, it running VERY rich and TOTALLY worn out.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Since putting it on the road last week, I've put 700 miles on the car, mostly highway, mostly at 80mph
-John
John,
Here are a couple of threads that you might find useful. MFI thermostat spacers MFI tools for DIY'er Lots of info in here, including good details on some specialized tools that you'll need to make or buy.
John |
by the way, I have my 2.4 tuned pretty well (it still needs some tweaking) and its power is more than adequate for me. Kind of hard to describe how powerful an engine feels though.
John |
I had a 1969 911T 2.0 litre car.
Although it wasn't fast for a Porsche, it was comparable to most 2.0 litre modern cars (which probably are much heavier). It was faster than my 2.3 litre automatic SAAB.
1969 911 T (SOLD), 1977 911SC (SOLD), 1999 BMW M3 (SOLD), Current Car 2005 Lotus Exige |
Your GLI is around 134hp, and is probably heavier than the 911. So even at only 140 hp, your 911 should have a better power-to-weight ratio than the GLI (not to mention that it should have a lot more torque).
Your 911 if stock, would have been a significantly faster car than the GLI. Even with the smaller engine, it should still not be a slug. I suspect that your 2.4 is not set up/tuned correctly. -MAS
77 911S Targa (current car) 87 924S (my previous car) |
Skimming the CMA article, it appears fairly technical & some tool fabrication required. I much prefer to do this myself & learn or at least work with someone with the nohow. Is there anyone local who has done this before who wants to tackle this with me? -John 06776 or 12594
There is no way your GLi should be "quite a bit quicker" than a 2.4T 911. Something is definitely not right. I've owned GLi's and have driven a stock 2.2T and the 2.2T was quicker .....
I use to have a really well tuned low mileage 67K miles 1973.5 2.4 911T CIS.
It had a dansk sport muffler and MSD Ignition, aside from these it was a stock motor. It was actually pretty quick, I easily took 3rd gear all the way up to 100MPH when I shifted it to 4th it would turn 110-120 MPH easily and still pulling. My friend who use to race cars has a stock low mileage '85 GT Mustang and he said my porsche was much quicker. He also went to a porsche school and studied under Jerry Woods and he works on my Porsche personally. So a well tuned 2.4 CIS is not that slow. I heard a MFI is even a bit quicker. |
Also bear in mind that the lower displacement engines do not come alive until about 3500-4000 rpm and then peak out at about 6000. If you are shifting at 4000 (like most first timers do), you are missing the best part in terms of power and sound.
fancytown
My 2.4T has little power off the line. I consider 1st and 2nd gear are present just to get the car moving. Playing around in 3rd and 4th, while working the car's mid range is fun.
all cars sold. |
Bandwidth AbUser
Toast, it's nice that you have MFI.
With the info available here on Pelican and using the CMA procedure, you should be able to liven it up some more. MFI cars rock!
Jim R. |
What kind of transmission does the car have, 901 or 915?
Steve F 69 911 71 911 87 Carrera 2004 RAM 1500 4x4 "Hemi" |
Even though the car runs well, based on opinions thus far, I really should be getting more out of this motor. I will start digging & post results as it progresses. p.s. I havent found the tranny code yet while crawling under the car. It is a 5 speed. TIA, -John
Bandwidth AbUser
If reverse is directly below 5th, it's a 915. Otherwise, 901.
Jim R. |
You say it is running smoth; a sign of a health MFI.
Be sure to re-check your point gap(or dwell), then adjuct ignition timing. I like to adjust more advanced than spec, try up to 38 deg @6k, back off if detonation or a decrease in top end power. This will give more kick at the low end. PS; Never take off that MFI system, nothing beats it.
'69 911E 2.7MFI ;996TT;987.2 CaymanS '71 Volvo P1800E wife's; AMG SLK wife's '71 Volvo race car 944S; 986S ; 734WHP drift car (son's) |
I have a '73.5 T (CIS) and it certainly feels much better than any 140hp engine has a right to feel. Maybe it's the torque, maybe it's the car's low weight, but it sure likes to rev too.
dave 1973,5 |
