Sleep Deprived and Grumpy
jwernquist's Avatar
Replacing the Front Calipers:?
I have to replace my front calipers and damn those 2 bolts are on there.? Any suggestions? A little heat? Or just keep cranking on em?
Any advice?
Jon
jwernquist@wi.rr.com
262.215.6547
Old 10-07-2004, 07:55 AM
Somewhere in the Midwest
MotoSook's Avatar
I use a breaker bar.
Old 10-07-2004, 07:59 AM
jwernquist's Avatar
Alright.. Thats what i will try to do here in a bit! I have an old pipe i attach to a wrench or socket that usually does the job. But... My first attempt didnt go so good
262.215.6547
Old 10-07-2004, 08:10 AM
I would rather be driving
jpnovak's Avatar
I have bumped my breaker bar with a dead blow hammer before. This usually works great.
Old 10-07-2004, 08:23 AM
jwernquist's Avatar
I will give it a shot later today! Wish me luck!
Jon
262.215.6547
Old 10-07-2004, 08:26 AM
MotoSook's Avatar
Jamie is right. A little shock from a steel hammer (forget the rubber mallot..it don'ta do a no goot!) will be just enough to break the corrosion fused surfaces.
Danimal16's Avatar
Would it hurt to put some wd 40 or other penetrating oil?
Dan
Dan
Old 10-07-2004, 02:06 PM
mackpipes
Guest
Posts: n/a
PB blaster and a dead blow BFH worked for me.
Old 10-07-2004, 02:57 PM
CRNT918's Avatar
Make sure you use a six point socket!
PCA-Chicago Region-DE Tech Coordinator-Retired
PCA-Chicago Region GingerMan DE Co-Chair-Retired
1987 Cab-under construction-Sold pending pickup
1986 911- Race/DE car-Sold
Old 10-07-2004, 03:22 PM
Probably not a recommended procedure, but I had one bolt I could not get unstuck by banging, penetrating oil or anything else. I used a breaker bar with the shortest socket I had. I positioned the bar parallel to the garage floor and put my floor jack under the end of the bar. Though it was nerve racking and almost lifted the car off the jack stands, the bolt finally turned.
Not for the careful, cautious or the faint of heart.
Parkin Hunter
80 911 SC Targa
Charlotte, NC
Old 10-07-2004, 06:23 PM
