-   -   Part source for early (1969) 911 Bosch CDI box? (http://forums.pelicanparts.com/porsche-911-technical-forum/186071-part-source-early-1969-911-bosch-cdi-box.html)
H.G.P. 10-07-2004 09:50 AM
I'm looking for availability of Bosch (rebuilt) early 1969 911 E, CDI box.
My first choice was Pelican, but only MSD and Permatune are listed, and furthermore on of my catalogs had the dreaded NLA for my year 1969.:(
pwd72s 10-07-2004 10:22 AM
http://www.systemsc.com/
jpnovak 10-07-2004 10:26 AM
Also, any 3-pin Bosch box will fit your car. These were used until 77.
If you search the archives there are a few sources that can rebuild one if you find a dead one.
H.G.P. 10-07-2004 11:15 AM
OK thanks all.
Lorenfb 10-07-2004 12:28 PM
"My first choice was Pelican, but only MSD and Permatune are listed, and furthermore on of my catalogs had the dreaded NLA for my year 1969. "
Not true! Pelican has many parts, and sources for them, not listed on the web site.
You need to call and ASK! Talk to Tom Gould at Pelican.
What's happen to phone calls and one-on-one discussions/questions?
Email & the internet have caused many to forget that they still have a phone.
H.G.P. 10-07-2004 02:03 PM
I was refering to the online catalog for Pelican Early Parts. I see listed both Permatune and MSD on the Early Parts Catalog Online. I had to go to work so I have not yet had time for calls. I'll call later and find out. Thanks for the information, I'll check with them.
H.G.P. 10-07-2004 02:58 PM
OK I called both Pelican and Stoddards. Neither carry Boch CDI boxes, as I undersatand you send your unit in to repair, and then Pelican sends it back. However, since my box is a Permatune, it matters little. So the alternatives:
1. Take the unit out and the coil and clean everything best I can.
2. Examine the unit outside.
3. Examine the unit inside, and take a picture and post here online.
4. Maybe purchase one of the epoxy Blaster coils that Warren recommends, and the then reinstall everything back, including the old unit, and see if it works.
5. If the above fails, then try MSD with Joe's diagrams on Pelican in the search function.
6. Last.....a question.....can the alternator have any effect on no spark at all?
chibone_914 10-07-2004 04:06 PM
Hey HGP,
Send me your Permatune box, we repair those as well!
Lorenfb 10-07-2004 06:26 PM
"OK I called both Pelican and Stoddards. Neither carry Boch CDI boxes, as I undersatand you send your unit in to repair, and then Pelican sends it back."
So find a core or pay a core charge. You should be able to find MANY 3 pin
Bosch cores. The 6 pin ones are the difficult ones.
H.G.P. 10-07-2004 09:18 PM
I pulled the box this evening, and it definitely is a "blue" box Permatune, so from Warren's comments on another thread, I'm first going to see about keeping this one. Thanks for informing of possible options.
Current diagnostics ('bench test") are on the other thread. Right now I'm questioning the coil.
Tim Polzin 10-08-2004 08:38 AM
H.G.P.
I have a core 3 pin CDI box from many years ago that may or may not be rebuildable, but I'll send it to you free.
If you want it, PM me your address and I'll ship it off to you.
Tim
Lorenfb 10-08-2004 09:13 AM
Since you'll have a Bosch core, Pelican Parts should easily be able to supply
you a rebuilt Bosch unit. If you have the original Porsche coil (the small one),
you'll not need another coil. The original coil is very reliable.
