Front pan in. Wait until you see what's next!
Lessee here, where do I put this?
OK, I'll use some welding rod. I left the pick up points there until I could scribe it in. ![]() Right below where I want it. Double cut. Cut out the rest and it's in. 20 hours to do this, maybe I'm slow. I had to take a little peek at tomorrow's project. Yeah, that's the heat tube you see there. ![]() Bondo DOES hold things together That big blob at the left in the pic above is BONDO. I found this and more up in there along the tube and around the jack receiver support. All that to the right of my glove is more bondo stuck to the heater tube.![]() (I had to put another : eek : in there because that's what it is!)
Thanks for the pics Zeke. I think just lost my appitite (along with dinner) for rebuilding a very rusted early model. Good luck on yours and my admiration for your devotion to saving this 911.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
I would rather be driving
And I thought my rockers were bad. Good luck fixing it. Looks like you are off to a great start! I am sure your S will be happy when its over.
Is that originally a CA car? Maybe a beach car.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Did you get the memo?
To say I admire your ambition is an understatement. Very nice work, saving an early car is always an admirable cause.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Anyone know what a typical price is for having that front suspension pan welded in by a shop? Also, does this need to be done by a Porsche shop, or could a well regarded welding shop handle the geometry and nailing the pickup points as well as Milt did?
A little math says 20 hours x $70 = $1,400 + $250 in parts, and this turns into a $1,700 project!! But, then again, maybe Milt is slow. Thoughts? JA
John - '70/73 RS Spec Coupe (Sold) - '04 GT3 |
Zeke, your dedication to saving this car is definitely admirable, especially since it's an "S" Good luck with the project and keep posting pics!
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
Here's what it looked like Monday when I opened it up. And yes, I must be slow, but who's pushing me? If I want to stop for a while and sit in the seat and make motor noises, then I'll do just that. I'm afraid the rocker is going to take more than 20 hours.
20 hrs start to finish on a good? rusty car. Early front pans, 1200, late pans due to airconditioning 1500, plus any further lateral gas tank support /wheelhouse/ batt or bumper support welding is more time n $.
Milt , the welding rods are your height? The length is pretty well determined by the a arms, critical dim. 19 3/4? anyway you must be certified crazy by your CA peers , that rust repair in CA? maybe on a 356! If you like that work, come to the NE...
Damon @ SERIES 900.com Sunapee NH several 911 variants |
Zeke, I have been admiring your posts for a while but this one inspired me to respond. I'm working on a 68 swb with similar rockers (or lack there of as the previous owner removed them) and I live near Lexington, Kentucky. But my question is this, are the heater tubes structually important or can they be removed for weight savings. It is going to be a drivers ed and occasional street car (without heat exchangers). Thanks for your posts (especially the saw-zaw ones). Tom
Non structural, factory deleted these in RSR's of the day. the rear tubes up the longitudal are very difficult to remove without major surgery. With the inner /outer rocker replacement, the muffler and the front tube are easy deletes.
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler |
drive in- drive out painted and undercoated, start to finish, its a 2 day job. Bare tub i can see 10-13 hours, there is a bunch of parts that need to be removed and reinstalled, and due to the rust, prior repairs/damage, things do not always go smoothly. Bare tub repairs I do on the Celette bench, and I can raise the car up and down on the lift off the jigs, and i reinstall the rotisserie for easy grinding. Drivers demand more time in dis/reassembly for pan replacement.
In any case if I have this done I'd want it done right....a cheap job would cost me in the long run!
minivan - all stock |
That is, if this car doesn't kill me.However, you all would be surprised how bad things look when you first tear into them. Once you get the offending panel out, things start to look doable. Rust is a mysterious thing. The innner and outer rockers on one side are toast, yet the floor pan and pinch seem that the rockers attach to is solid. Good thing, or the white flag may come out. This car will live to see the track. |
What are those little things all over that last pic?
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
More Likeable IRL
i admire your efforts. my tears would create more rust on a project like that if i was to undertake it.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Are all those white circular things barnacles? That would bring new meaning to the barn find story -
Bill |
