Fiberglass doors - 935 style?
I want to install fiberglass doors, and I was thinking about going with the 935-style door, with the sliding window. I haven't found any good, clear, up close pix of the 'mechanism', which is really a simple slider like the split-window VW bus.
RennSpeed has the 935 doors, but it's not clear how one would set up a latching mechanism. How do 'normal' people latch these doors? Thoughts? Anyone here done this?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Navin Johnson
those doors latch using the stock hardware. that 935 door is stock door shape that was widened. you could alos use one of the smart racing lighweight door latch kits, but still the latch is in the same place as your everyday 911
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Are you going to add another bar in your doorway for additional impact protection??
Thanks Todd I drank what? = Party out of bounds - PriceLESS - BudWIZER "Boy Im gonna burn you a new one! - A new what officer?" = night in jail 993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Administrator
Are you going to add that tail end?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Cage - yes; tail - no.
why not go with 911R doors in that case? lightweight, not widened, same locking mech as stock door.
74 911s neverending story. two feet and a jetta for now. |
Roughly how much weight do fiberglass doors save over stock doors?
Rob Fusi 77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s | GTC Motorsports |
I think 150 is a bit optimistic. Probably about 30lbs per door for 73+ just for the fg substitution. Changes to lifts, glass, and hardware can save more. pre 73 doors without the impact beam are about 10 lbs lighter.
Chuck Moreland - elephantracing.com - vonnen.com |
Ahhhhh.... what cage can you use and maintain the cab top???
Just do it Thom and post the pics!!!
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Errr... welding on a top or going comando?
I found that Spektr makes the windows I want. Almost $400 - oye! I can probably fab them myself for yes....
As the to top, I'm really tempted to get one of the fiberglass repro hardtops. I can sell my soft top to partially cover the outlay. Right now I'm in the due diligence phase trying to locate all of the various bits I'd need. Here's a shot of the windows. I'd also do a vent in the front quarter window for extra driver cooling. http://www.spektrproducts.com/viewCatalog.asp
