-   -   White flag of defeat could be displayed soon. (Rust) (http://forums.pelicanparts.com/porsche-911-technical-forum/186241-white-flag-defeat-could-displayed-soon-rust.html)
Zeke 10-08-2004 12:50 PM
You better believe when they say it you can see rust, there's a lot more you can't see. This pic shows the area to be investigated.
http://forums.pelicanparts.com/uploa...1097267997.jpg
Here's what's behind.
http://forums.pelicanparts.com/uploa...1097268060.jpg
All of this debris came out of that hole and there's twice as much more in the shop vac.
http://forums.pelicanparts.com/uploa...1097268122.jpg
I actually had the inner rocker trial fitted here last night, but I wanted to make sure I had access to the suspension console before I welded it in.
http://forums.pelicanparts.com/uploa...1097268223.jpg
I'm now going to go to the other side, which doesn't look as bad on the surface. If it is, I may be real discouraged. You know, I shouldn't have done all the bodywork on the top side first. Starting at the bottom, I would have parted it out instead. If and when this car gets painted, it will be a damn good looking and straight car. It certainly won't give any indication of the condition of the bottom. :(
EDIT: Make sure you read my other follow up posts here. This is not the whole story.
jpnovak 10-08-2004 01:00 PM
I am so sorry you found that Milt. Actually, I am glad you found it now before you started all the work welding in the rockers. At this point, If you can access the rusty parts, make patches and weld them in. You are about as deep as you can get.
I will have a beer for you tonight. You will need a few.
concentric 10-08-2004 01:03 PM
Don't take any guff from those swine!
You're doing an awesome job, keep up the good work.
JCM
Zeke 10-08-2004 01:14 PM
BTW, you wonder why you can see red overspray on the oil lines and heater tube? That's because the PO painted the car with the gaping hole in the inner rocker.
Just a bunch of GD idiots!
No offense to the guy I bought it from or the guy that looked at it for me. I knew what I was getting into. And, I could have parted the car from the get go and made money.
As it is, I have nearly covered the purchase of the car by selling the deep sixes and sport seats. So, it's almost a free car except for the enormous amount of labor.
It will be a street legal track car, not some garage queen. But, we all knew that anyway, eh? ;)
jpnovak 10-08-2004 01:26 PM
Why don't you cut out all the sheetmetal and use round tubes for the build up. :D I see a 935 in the making...
I found similar stupid repairs on my 71. My favorite was the fist sized ball of newspaper and bondo. The list goes on.
Jim Sims 10-08-2004 02:57 PM
How does the statement go: "Don't walk away from a rusty 911, run!" Jim
project935 10-08-2004 03:19 PM
Zeke - could you do me a favor while you're in there?
I need the diameter and depth of the big torsion bar bushing hole in the framerail - the hole in the outer rail and the sleeve inside it.
Thanks!
michel richard 10-08-2004 03:20 PM
Milt,
I've done this before. All you need to do is focus on one patch at a time. Take satisfaction from each repair, do them one at at time.
If it takes a little longer because there's a little more rust, that's not a problem.
From what I've seen you're doing a fantastic job.
Michel Richard
Joe Bob 10-08-2004 04:02 PM
Grind it...spray it ....drive it until it breaks...then move on.....
vanwyk4257 10-08-2004 04:40 PM
Zeke, since it's going to be a track car just weld a jungle-gym of a roll cage in that baby and tie the front and rear members into the cage. You won't even need solid rocker panels! Just Kidding, keep fighting the good fight!:D
TimT 10-08-2004 04:45 PM
Milt, perseverence, let the rustoration be a zen sort of experience. I believe it was you that asked me why I bothered when you saw the pics of my rustoration
I did itbecause I had all the parts, for the tub, for the engine, roll cage suspension etc.
When I saw how badly the tub was rusted I took it as a challenge to fix the tub. Im almost done. I installed the engine management last week, and cranked the engine, I have spark, and the noid light blinks, so I have fuel too. All I have to do now is finish my front mounted oil tanks and associaterd plumbing..
To properly fix some of those areas you have to open up quite a bit of sheet metal to allow access, and to allow good positioning of the torch etc.
Chuck Moreland 10-08-2004 04:58 PM
Originally posted by Zeke
But you can ignore the white flag BS. This car will live to see the day it raises hell in a canyon nearby. And we'll see if I can drive it to it's potential at the track. I have a sticker on my tool box from the karting days that says, "When the green flag drops, the bulls--t stops." That's kinda how I feel about everything. So, I'll see this through.
You had me worried for a minute there, but now you're talking. That's the Milt I thought I knew. I can't wait to see it finished.:)
onewhippedpuppy 10-08-2004 05:07 PM
Awesome work Milt, it's going towards a good cause. Keep it up!
pwd72s 10-08-2004 05:15 PM
Milt, far be it from me to give advice to somebody with your hand skills. If you ever need a shoulder to cry on, there's beer in the fridge, and Cindy makes great blueberry pancakes...just ask the guy you sold the seats to. Good luck in whatever you decide! :)
azasadny 10-08-2004 05:19 PM
Milt,
Keep going, don't give up!!!
nostatic 10-08-2004 05:35 PM
Milt can't white flag this. He's *sick*. :p
I'm sure the two-tone primer beast will be at Willow in '05.
sithot 10-08-2004 08:04 PM
Hat's off you Milt. I don't have the patience.
Good luck.
Tom
phishhead 10-08-2004 08:47 PM
Don't be a pussy Milt, buck up you, and get back out to the garage.
Cornpanzer 10-09-2004 05:26 AM
Go Milt Go!! You are a rare California Porsche enthusiast......one that can say he has fixed rust. ;)
Craig 930 RS 10-09-2004 10:09 AM
It's an 'S'......well worth saving!
Bob's Flat-Six 10-09-2004 01:17 PM
I took Rust 101 back when I was ( let me think?) 26 or in 1978 or there about's.
A 1965 Corvette roadster, not from Calif.
Hey, it's fiberglass how bad can rust be. This was a So Cal boy's logic. Well after sandblasting and using rust stop chemicals, Liquid wrench etc. etc. I cleaned it up pretty nice but the mental scars are still with me.
Even a galvinized 911 will get rust on every nut and bolt that holds it together if their exposed and not protected. Just to bleed the brakes can turn into nightmare.
I feel you pain, Milt SmileWavy
Rust sucks
kycarguy 935 10-09-2004 01:28 PM
Keep up the good work. If nobody ever fixed rust then there wouldn't be many 356's and early 911's on the road today not to mention other collector cars. I agree with you too Craig that an early S is very much worth saving.
1973911s 10-09-2004 02:13 PM
Milt,
I am a few towns over and can bring in some beer, just make the call.
Michael
Shuie 10-09-2004 03:52 PM
Sometimes beer doesn’t help.
Here's to Kentucky! :D
http://forums.pelicanparts.com/uploa...1091818459.jpg
Milt, keep up the good work. It will be worth it in the end. Besides, you are going to need something to drive while you work on the Speedster.
The rust repair that guys like you, Jamie Novak, dtw, and thrown hammer have displayed here is what made me want to buy a welding machine.
Zeke 10-09-2004 04:22 PM
Rust sucks
Bob, that is so weird. My 3rd car at age 18 in 1966 was a '61 Corvette. It was from Michigan, so you know that story. The owner had skipped from MI and was in CA. When the finance company finally got the car, I bought it for $1200 dripping wet and soaked from a good CA rainstorm. The top leaked horribly. Nobody wanted it but me, the fool.
I don't think I got one bolt off that car w/o breaking it. I took the car apart to the bare frame. I had never worked on a car before. It took me 2 years to put it back toghether. I got a trophy at a couple of shows and sold it. I bought a '55 VW convert next and that began a long affair with German cars.
I had an old Chevy truck to chase parts in. I have never been w/o a Chevy PU since and I don't think I have ever been w/o a German car; lots of VW's, some Porsches and one Mercedes 250 SE sunroof coupe (also a rust bucket).
Anyway, today I made a piece to fit a patch area (the big gaping hole in the first post).
http://forums.pelicanparts.com/uploa...1097367480.jpg
Goes right up here.
http://forums.pelicanparts.com/uploa...1097367543.jpg
If that's the toughest one, I've got it made. :D
jpnovak 10-09-2004 04:38 PM
Very Nice! Keep going your almost done. :D Every little step seems like a milestone in a project like this. The worst are the days where you spend lots of time in the garage cutting and welding and then it looks like nothing happened. But the next time you finish the chore and it looks like lots of progress was made.
Zeke 10-09-2004 04:40 PM
Sounds like a room addition I once built (except for the welding ;) )
Bob's Flat-Six 10-09-2004 04:43 PM
Hand made--- Twice :D
speeder 10-09-2004 04:58 PM
Nice work on the sheet metal fabbing! :)
The big problem w/ 911s being rusted in that area is the torsion tube; I know of an early 911 that looked pretty clean on the outside but had hidden rust in the tube. Guy was driving down the road when suddenly, "wham" , the rear end of the car was resting on the tires. It is an absolutely fatal injury when you price a new tube, (only available from Porsche), and the body shop labor to install on a jig, complete disassembly of the car, etc....
Rust sucks. I hope that it works out OK. :cool:
john70t 10-09-2004 05:34 PM
I had the same problem, same place, same patch but smaller(yours looks a whole lot perttier though).
That hidden inner support wall was starting to go as well.
I cleaned as much rust, sprayed a buckload of rust-kill in there, welded in the patch, ground/fiberglassed the edges, and POR15ed the entire underside after scraping all loose factory Weynol(?) undercoating and treating all surface rust.
It's still not a chem-dip but it'll buy some time.
Next step is Wax-Oyl or a similar neutralizer/encapsulator.
The problem with early cars is the little "bucket" in front of the back tires. It catches dirt, dirt catches water, water eats through metal forward, down, and up. I patched those, foamed, smoothed, fiberglassed, and painted. Now theres nothing for flung dirt to stick to. Not concours, but hopefully problem solved.
Also, if there's a panel that needs to be made, all it takes is steel, tools, and a little skill and patience. Check out links in www.metalshapers.org
Chuck Moreland 10-09-2004 07:40 PM
You are doing God's work, making that which is wrong right once again. Tis a noble deed.
It always looks impossible, until you start trimming, welding and hammering. Then somehow - miraculously - it all just starts coming together. But you already know this.
Keep at it, we are all here for moral support.
Craig 930 RS 10-09-2004 07:46 PM
Damn, I almost want to take up a collection to make it right again. Seriously!
Rust is almost like a death.........the (fill in the blank) is just *GONE*
nostatic 10-09-2004 09:26 PM
Milt has mad skillz. This should be made into a made-for-internet movie.
MY911S 11-02-2004 11:04 AM
Hi Milt,
I just did a search on the topic and saw your project. I may be in the same boat rust wise and wondered if I could check out your work sometime (you're in Long Beach, right). I contemplated doing the work but wanted to see first hand what i was getting into.
regards,
Carlo
Shaun @ Tru6 11-02-2004 11:27 AM
Milt, you've got to soldier on, not sure how long I'll be waiting, but I really want to see those door posts put to good use.
Remember the car I cut up for the posts? Your rust is nothing compared to that one. You've actually got metal you can weld to!
