Whats the best brake pad
WHat is the best brake pad that I can use for 95% street and keep down on dust and squeling?? I am doing a complete brake job so now is the time
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 10-11-2004, 05:15 AM
Bill Verburg's Avatar
Axxix metalmaster, I believe they are also marketed as PBR
Bill Verburg
Old 10-11-2004, 06:01 AM
Designer King
Paulporsche's Avatar
Ditto. Good all around. No dust or squeel. No accelerated wear on rotor.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-11-2004, 06:10 AM
I had heard they were good. Any other ideas? I want do this once as I only drive about 2000-3000 a year it should last a long time
Ben
89 944,85.5 944
914-6werkshop.com
Old 10-11-2004, 07:07 AM
Originally posted by mb911
Any other ideas?
Sure.. follow Bill's lead.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-11-2004, 07:16 AM
That sums it up. Great thanks metal master it is!
Ben
89 944,85.5 944
914-6werkshop.com
Old 10-11-2004, 07:18 AM
I use the axxis soft pads on the street.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-11-2004, 07:30 AM
I've found Pagid Orange to be an expensive but v. good dual-purpose pad. In applications with 4 puck discs, they tend to squeel, ans some say they dust too much too...but I haven't found that to be a big problem. As long as you go through the bedding-in routine, these are the best high performance dual purpose pads out there, IMHO.....
Although in this "category" I believe the newer Ferodo 2500's might be the ticket too. Ask Steve Weiner of RennsportSystems about the Ferodo's.
Otherwise....MetalMaster is a good choice....the softer "deluxe" work well for the street but I would prefr the Metalmaster over Delux for any kind of dual-purpose track use.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-11-2004, 07:35 AM
Binge User
Schrup's Avatar
I like the Porterfield R4-S, great performance, less spendy than the Pagid, Ferodos, or Hawks.
http://www.porterfield-brakes.com/pads.html
Paul
Old 10-11-2004, 08:03 AM
I would rather be driving
jpnovak's Avatar
I have been using the Ferodos on the targa. Its just the street formula. I think the 2500s are track pads. They are great pads for the street, very little dust and hold up well on the track. I really like them but don't have much to compare. the ST has some stock SC pads in them. They suck in comparison. No bite at all even when warm. I was going to switch but have a Big Red system to install instead.
Old 10-11-2004, 08:10 AM
Jeff Alton's Avatar
I also use the Porterfeild R4-S. They are great on the street and hold up far better than the Metal Master on the track at a DE (IMO). They give off about 5% of the dust that the factory pads do. They can get a little bit noisy after a track day, but simple cleaning of the rotors and pads with brake clean quites them down.
Jeff
www.turn3autosport.com
Old 10-11-2004, 09:11 AM
