porschetuner's Avatar
Porsche Crest Need Some Lighting Help
Hey There, I just aquired a 79 SC Targa and I've started working on fixing the things that need fixing. Im having problems with the head lights. When I go to use the high's the lights turn Off!! whats up with that?. Hopefully someone can direct me on what todo.
Race till it Breaks Then Fix it
Graphix Zone Inc.
Old 10-09-2004, 10:10 PM
Re: Need Some Lighting Help
at the top of a page is a "search"
type in headlights
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-09-2004, 10:40 PM
Send a message via AIM to fintstone
It is most likely the stalk/switch (turn signal lever). Sometimes you can adjust the contacts a bit and fix the problem if they are not burned or damaged. Burned or melted contacts are a common problem..especially with higher output bulbs. Most folks add relays to the circuit to help prevent this.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 10-10-2004, 06:35 PM
maybe both bulbs are bad?
1984 911 Euro Cabriolet
1988 928 S4 with Murf Supercharger S1
Old 10-10-2004, 08:32 PM
It's the turn signal/headlight switch. Same thing happened to me. Buy it at Pelican and fix next weekend...
1987 Carrera Targa
Old 10-11-2004, 05:40 AM
Thumbs up
Thanx for all your help will check on the switch
Graphix Zone Inc.
Old 10-11-2004, 10:20 AM
