Brake Calipers & POR-15
In case any of you ever want to do this, here are before and after pics of 930 calipers painted with POR-15. I used the regular POR-15 as a base coat and then the semi-gloss Chassis Coat as the top coat. I painted them with a brush, so the whole project will be about $10 in materials and a lot of time (for some odd reason I decided I needed to paint the back sides as well). The POR-15 guys say this is a great combo for calipers - 700 degree heat resistance and a very durable finish. I hope they are right.
Bill
Old 10-11-2004, 10:31 AM
Hilbilly Deluxe
emcon5's Avatar
Where did you get the POR15? I am trying to find a local (Fremont) place that stocks it.
Tom
82 911SC Coupe
GTI Cup #43
Old 10-11-2004, 10:55 AM
Tom - I ordered it online.
Bill
Old 10-11-2004, 11:01 AM
Bill Verburg's Avatar
Lookin goood! The Wurth equivalent product(Rust Guard) also works well for that sort of thing.
Bill Verburg
Old 10-11-2004, 11:05 AM
Shaun @ Tru6's Avatar
on rusty body parts only, I've used both Wurth Rust Guard and POR15.
I prefer POR15 having had a few adhesion problems with Wurth. Used the recommend cleaner/acid etcher systems in both cases.
looks great, looks like a good project when I rebuild my 930s.
Did you cover the PORSCHE and then sand off or carefully paint around?
Tru6 Restoration & Design
Old 10-11-2004, 12:49 PM
Hey Shaun - the worst part of this project is the cleaning. 930 calipers have so many nooks and cranies (for lack of a better description) it is a real PITA to get them reasonably clean. I used lots of the degreaser and then treated them with the Phosphoric acid solution prior to painting but I never really felt like they were squeaky clean.
As for the Porsche logo, I sanded it clean prior to painting and then just painted over it. I painted that part last and then took a small piece of rag dipped in the POR-15 solvent and gently wiped the paint off the lettering while the paint was good and wet.
Bill
Old 10-11-2004, 02:04 PM
scca_ita's Avatar
check ebay - I bought mine there
Old 10-11-2004, 02:42 PM
I would rather be driving
jpnovak's Avatar
The brakes look great. they make some wonderful products.
Also. www.por15.com
Old 10-11-2004, 03:16 PM
You do not have permissi
john70t's Avatar
The cali distributor I used was at (800)827-6715. I think they were bay-area'ish because devivery was within a few days.
I've ordered 3 6-packs(only use what's opened) and a couple starter kits. Prep is definitive because it doesn't stick to paint well or any oil residue.
I like the product so far. The only things I worried about was the stickum/rust-sealing on the wheel arch edges, and once I got a batch that was kinda lumpy like it'd been sitting in a cold Indiana warehouse over winter.
Old 10-11-2004, 03:46 PM
Hilbilly Deluxe
emcon5's Avatar
Thanks for the pointers, I found a local place that carried it, and picked up a quart.
Tom
82 911SC Coupe
GTI Cup #43
Old 10-11-2004, 04:10 PM
I hope it adheres to paint o.k. as there is really no way for me to strip the 930 calipers.
Bill
Old 10-11-2004, 04:28 PM
john70t's Avatar
I also found it also disolved a bit with brake cleaner, which they claim it doesn't.
The good thing is it supposedly doesn't vent carrier solvent to leave micro air holes to oxydize rust. It seems like a plastic paint so I hopw it holds up on the calipers.
Looks good.
Old 10-11-2004, 06:09 PM
It is pretty interesting stuff. I have been using a plastic dish as my paint holder and when the left over stuff dried I was able to peel it out in a sheet. It was very flexible and quite strong. POR-15 claims that with the top coat it is even stronger so when I did the Chassis coat I painted the piece of base coat I had pulled out of the plastic bowl earlier. When that coat dried it was even stronger. In fact, I would think that you could hold your car together with this stuff. I patched a few harness belt holes in the floor of my 69S with fiberglass cloth and POR-15 and it also set up very solid.
Bill
Old 10-11-2004, 07:42 PM
