Update to 964 engine cover
My 82 SC
Would look better, for the addition of a retractable
rear spoiler, but electrics aside (for now)
it appears to 'splay' the hinges apart, when offered up.
I'm told this has been covered on these forums before
can anyone offer any advice
cheers everyone
Richard
Old 04-22-2006, 10:20 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
I dont speak British, but if you're asking about fitment issues, you have to change the hinges to the 964 type or modify the ones you have for it to fit.
Marc
Old 04-22-2006, 11:00 AM
Nineteen Ninety One 964
Old 04-22-2006, 12:42 PM
Porsche Junky
mede8er's Avatar
Funny, I'm here 'across the pond' in Florida doing the same job....this sure as hail ain't 'plug and play'.........
1986 930 RUF equipped
This is as far as I've got
its dark outside and I'm stopping for breath
AS I'd been warned, the hinges look like they will need
SOME sort of adjustment.
Hopefully by merely drilling some extra holes in the underside of the engine cover,
I can simply move that captive nut thing to the side a bit within the cover itsel.f
what do you think.
Old 04-22-2006, 12:51 PM
Porsche Junky
mede8er's Avatar
I'm inclined to go with the 964 hinges if I can find a pair.....I need to take the wing assembly fully out as you did.....
Old 04-22-2006, 01:02 PM
wing
might I suggest
leaving the moving part as together as you can,
just pop off the x8 spring washer/clips
the x3 Allen keys either side
and the fixed grille is the final bit to be removed
mine came out fairly easily
wish I d taken some pictures as I went along though
as I suspect getting it all together again when painted might just be interesting
Have you considered the electrical side yet?
I'm going with a spring-loaded toggle switch in the dash
as I cant quite make head or tail of the micro-switches
If you have a solution I'd be VERY interested in looking at it
Richard
Old 04-22-2006, 01:10 PM
Porsche Junky
mede8er's Avatar
Toggle switch for me also.....I'd only raise it on the highway.....
Old 04-22-2006, 01:45 PM
I dont' know how you saw this.
for myself I intially decided, it would raise as soon as the engine started, but with th option of switching it 'down'
but with a warning light on then.
Instead I wondered, whether to use the micro-switches
but it looked a bit involved,
so a rocker switch like a window riser looked the best bet
perhaps with smallest in-line fuse I can get,
should someone play with it and bugger the little motor
accidentally
Old 04-22-2006, 02:03 PM
Porsche Junky
mede8er's Avatar
This is not gonna work...my A/C evaporater won't let it close.....
Old 04-22-2006, 02:26 PM
This I was also told,
although the air-box was first mentioned
and the rear blower motor,
might also be in the way.
I haven't anything else in the way
don't suppose you have any pictures so I might see the prob
Old 04-22-2006, 02:32 PM
Porsche Junky
mede8er's Avatar
Sorry, no pics....but the plastic grill cage that sits under the bellows mechanism is crushing the fins.....
Old 04-22-2006, 02:51 PM
bugger,
there are x3 long shims clamped between the 3x allen bolts
and the nderside of lid, if you removed these, would it make any differnece
Old 04-22-2006, 02:54 PM
Porsche Junky
mede8er's Avatar
Bugger is right...I have the wing out...it's the plastic grillwork that hits it......
Old 04-22-2006, 03:19 PM
By how much
Old 04-22-2006, 03:30 PM
rattlsnak's Avatar
I can simply move that captive nut thing to the side a bit within the cover itsel.<<
If you do a search, youll find this topic has been covered a few times. If you use the same hinges you have now, you can just add spacers where they connect to the body, and bolt them to the original spots on the tail, or just get the 964 hinges and it will all bolt up just fine with no mods.
Marc
Did a search before I started
but nothing came up
where is it exactly?
Old 04-22-2006, 03:34 PM
scottcip1562's Avatar
Link to old post by Matt Man
Help! Installing 964 decklid on early car. Hinges and wiring?
79SC, Wevo Shifter, SSI, Koni's, MK Muffler
85 944 Stock
Past Porsche's
87 944
87 928S4, I was young and dumb
99 Boxster
70 911T
Old 04-22-2006, 03:50 PM
Thanks very much
that is just the info I was looking for
Old 04-22-2006, 04:11 PM
disband
juanbenae's Avatar
scott, returned your PM on the 964 deck i have for sale.
toby
Old 04-22-2006, 11:46 PM
