Early S rocker moulding question
I saw a picture of Dr. Porsches personal Carrera RS and he had S rocker moulding similar to the S bumper trim. This moulding piece looked like the T type moulding but had the thick S rubber insert. I like this look better than the standard '72 S rocker trim. I have a '72 and added Carrera flares. I want to add rocker moulding but the std S moulding is straight from front to back. I now have a flare so it wont work plus this trim does not bend. How can I get, make, or steal a piece of S type trim, like the bumper trim, to run along the side of the car?
Jon
The car was in an issue of 911 and Porsche World.
Old 10-10-2004, 10:32 PM
Jon,
That would be an RS rocker panel; touring equipment. It's flared at the rear to match the wheel well. Not sure how easy this is to find.
The flare is about the same size as SC flares, thus SC rockers will work, but not the same look.
Sherwood
Old 10-11-2004, 12:16 AM
Bill Verburg's Avatar
When I did The Carrera flares on my '72S i kept the oem rocker moldings
Bill Verburg
Old 10-11-2004, 04:20 PM
How did you manage that Bill? Did you just bend them out at the rear yourself?
Bill
Old 10-11-2004, 04:25 PM
Yes
The rear bumper ends were also oem, notched, bent and pieces welded in to match the contours of the RS flares.
Bill Verburg
Old 10-11-2004, 04:28 PM
Bill,
Can you post a close up picture of the bend? How difficult were they to bend without crimping the channel?
Jon
Old 10-12-2004, 11:03 AM
Yes, please, close up pictures and description of process if you would! I am planning to do the same to my car. Your car is gorgeous, by the way.
Old 10-13-2004, 06:44 PM
I'll look but i don't recall any closeups of that area. it wasn't a big deal. The bumper ends was where all the effort went.
Bill Verburg
Old 10-13-2004, 07:49 PM
Bill, when you bent out the bumper ends, did you have to add material to the length of the bumper? I started on one of mine and found that the bumper falls short of the flare by about the width of the bumper end cap. Did you add material to the length of the bumper, besides the gaps created by the notches?
'56, '59 356A Coupes
'67, '68 912 Coupes all gone
'72 911T coupe
Old 10-14-2004, 05:00 PM
Yes, I was fortunate in finding a highly skilled Italian metal worker. He had magic hands. As I recall he cut and welded the new material in the curved part of the bumper ends .i.e. not at the wheel end, but rather an inch or two back.
Bill Verburg
Old 10-14-2004, 06:24 PM
