911mot's Avatar
Talking Leaded fuel!
I've found that I will soon moving to a house thats just 5 miles from a station that sells proper, leaded, 98ron fourstar fuel.
Are there any adjustments I should make to get the full benefit of this stuff or just fill 'er up and go?
(84 euro non cat 3.2)
http://www.leadedpetrol.co.uk/list.htm
EDIT: It's 99.7ron
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 10-16-2004, 10:36 AM
Bill Verburg's Avatar
Evem though you don't have a cat, unleaded is still better for your engine as long as adequate octane is available.
Your sparkplugs and oil will thankyou
Bill Verburg
Old 10-16-2004, 02:22 PM
Send a message via AIM to bluebullet
yeah but one can never get enough of the lead...crank the timing up some and give it a whirl...leaded smells great .
I doubt you would be able to fill it right into your tank from the pump..thats against the law and if a cop catches you or an EPA official..you are gonna get slapped with a big fine and so is the gas station.
I used to bring a 5 or 6 gallon container and mix it with what i have left in the tank. Straight lead is nice but it kills your O2 sensor.
Carbuerated cars seem to run really good on the stuff.
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 10-16-2004, 02:38 PM
Designer King
Paulporsche's Avatar
Bluebullet,
I'm pretty sure 911mot lives in England.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-16-2004, 03:45 PM
Make Bruins Great Again
Por_sha911's Avatar
Leaded? This poses an interesting thought: won't the lead benefit the valves and valve guides? I imagine you would need to adjust the spark plugs for the change in fuel (?).
Joe
Old 10-16-2004, 04:32 PM
What a great idea. I'm going to Walmart to by some lead fishing weights to grind down into a fine powder and dump in my gas tank right away!
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 10-16-2004, 04:54 PM
HarryD's Avatar
This stuff Kale Auto will also be needed then.
"-MotorClean Internal Engine Cleaner-
Is the inside of your motor dirty? Most likely! Some people will tell you the only way to clean your motor is to tear it down and rebuild it. This is no good!!! KaleCo internals cleaner is a special combination of iron, graphite, and copper shrapnel of assorted sizes that work to sand and polish the inside of your motor! Add 2oz per quart of oil in your car. New engine clean powder should be used at every oil change! Bottle includes pouring mechanism. Comes in 16oz packages. Do not eat."
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-16-2004, 06:11 PM
Thanks for the tip Harry, It's simply BRILLIANT! What can I do to improve my transmission. I've heard saw dust will quite things down a bit.
1979 911 SC Targa
Old 10-16-2004, 07:16 PM
HarryD's Avatar
Once again, the folks at Kale Auto to the rescue!
Heavy Duty Clutch Belt-
A long time ago when the transmission began to slip, you'd know it was time for a rebuild. But! Rebuilds are costly, and half the time, not neccesary. What you may be experiencing is clutch-belt failure! KaleCo heavy duty kevlar belts are made with the quality you can expect from KaleCo. Please specify diameter and width of belt when ordering.
Harry
2020 MB E350 4Matic
Old 10-16-2004, 07:55 PM
