I have been looking around through old threads on mufflers and heat exchangers because I either need to get mine repaired and cleaned or get a new set.
Should I stick with my OEM 1974 exhaust system, or get a slightly used OE style dansk SS muffler and SSI's. Any opinions welcome Thanks |
I believe the SSI's are just a nicely made copy of the OEM 74 and older versions. Their build quality is most likely better, but I don't think you'll get the performance boost from them. I'm not sure on the muffler.
I suppose for both, go with what is more cost effective and/or more aesthetic. something aftermarket is probably cheaper than OEM and maybe even better.
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
You should sell me your 74 exchangers for $50 bucks and buy new SSis. No really the SSis are equal length headers with the heat exchanger body and complet 304 stainless. Versus just steel stock exchangers. The difference performance wise is very little. but every little bit helps.
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Author of "101 Projects"
I just put SSIs on my '72 Carrera RS clone...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Designer King
When my OE items went, I replaced them w/ SSIs and Dansk. For my 1980 engine, they made a huge difference since they were much better than the '80 setup. However, as Brother said, the SSIs are basically a stainless steel version of your originals. And Dansk is an OE supplier to Porsche. So I think the difference you will feel will be in the length of time these items will last, rather than in performance. Usually they are a little less costly than factory items, too.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 10-17-2004 at 05:35 AM.. |
The SSI are improved versions of the earlier exhaust I would want them on my car.
k thanks guys! SSIs sound like a good buy! But the question now is which dansk? 84mm or 1974 replica???
