pre packing rear wheel bearings
I am about to install new rear wheel bearings in my trailing arms. The new bearings appear to be pre-packed with bearing grease. Do I just install the bearings as purchased or do I need to do some disassmebly and pack the bearing before installation?
Old 10-22-2004, 05:12 PM
You don't have to touch them they are good to go
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 10-22-2004, 05:17 PM
Thanks...I figured as much.
My plan is to freeze the bearings and heat the hub ends of the trailing arm in boiling water. I'll then use my homemade bearing puller/press (threaded rod plus cast iron pipe reducer and washers) to pull the bearings into the hub as described on other threads on this site.
Old 10-23-2004, 01:20 AM
