sfierle's Avatar
Batteries for an Early 911?
First let me start by saying, I just discovered that the PO used lawn tractor batteries when he replaced them last time. I was quite suprised to see, after having start-up problems, that after looking at the batteries, they read "Lawn and Garden". After gaining my composure (major chuckles), I realize these probably were not powerful enough. My question for you folks, what should I do? What kind should I buy that are reasonably priced? Should I just go with a single large battery and place it in the middle (my previous one had it this way)? I want good starting power, and want to keep it as cheap as possible (I have other projects for this car half done).
1987 951: new toy
1971 911T: Sold
1973.5 911T: Sold
1983 928S: Sold
Old 08-25-2003, 07:40 AM
RallyJon's Avatar
Here's what I did:
http://www.rallystuff.com/pcar_electrical.html
993 · 911 · STI · S4 · rally car
Old 08-25-2003, 07:42 AM
I just had the same dilemma and opted for the single battery conversion. The good news is, there are numerous batteries with good starting capacity that will fit INSIDE the battery box.
I went to Sam's Club and bought an Exide battery for 29.00 (most people here suggest the Optima batteries but I was doing this on the cheap) that is about 525 CCA. When I went, I brought my u91150 (whatever they're called) inside the store to compare/measure the size. The battery slides right into the box with the posts sticking out.
The single battery conversion was very easy:
I put my new battery on the drivers side. I followed the positive lead from the passenger battery to the driver's side positive connector (they are both connected here) and disconnected it. This takes away the 'parallel' configuration of the two batteries. I left the wire there but removed the connectors and taped the ends up (in case you ever want to revert to the two battery set up). THe negative lead on the passenger side unscrews from the wall. That's it. EZ.
$29 Exide vs $77/each for two Interstate U911-50s or $100 for an Optima. Your choice. I'm El Cheapo.
Brad
1970 911E Sportomatic Sunroof Coupe (with an 8-track player)
Old 08-25-2003, 07:53 AM
Chuck Moreland's Avatar
The Odyssey PC1200 fits the box and even uses the factory tie down strap:
It has plenty of power as a single battery. The smaller Odysseys also have the power but will not fit the factory strap without modification.
Chuck Moreland - elephantracing.com - vonnen.com
Old 08-25-2003, 08:07 AM
Autodidactic user
David E. Clark's Avatar
I use the Odyssey as well. It works great with plenty of power -- even more power than the two factory batteries. I didn't have to lay mine on its side. It fit just right in the traditional position with a piece of 1 inch styrofoam behind it. Bought mine from JEGS. They had the best price I could find and a free shipping offer.
http://www.jegs.com/
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 08-25-2003, 09:32 AM
pwd72s's Avatar
If you're into originality, Sonnenschien, a German battery manufacturer, makes a gel cell that is the exact same size as the original batteries. I'm quite pleased with my pair, but they are $uper $pendy. If memory serves, they ran around $350 the pair.
Old 08-25-2003, 10:02 AM
I used a single Optima on the passenger side, helping corner weights. It too fits using the stock straps (just barely)
Per
Old 08-25-2003, 10:05 AM
Interstate makes the little ones that match the factory location. Been working in my 72T for about a year now with zero issues.
On the other hand, have you considered doing a replica of the extremely rare "John Deere RS" - green with yellow side graphics is the only way to go. You haven't lived until you've seen "John Deere" in the dropped down RS Carrera graphic style.
Scott
Old 08-25-2003, 11:11 AM
Don't laugh too hard at the PO's use of a "Lawn and Garden" battery, he may have used them on purpose as they are often designed and rated for "rough service", meaning they will withstand more vibraton and jarring than a normal car battery. Of course you must choose batteries of sufficient capacity.
Jerry M
'78 SC
Old 08-25-2003, 11:13 AM
Paul Valcourt's Avatar
On my 73 I took the dimensions of the original batteries went to Sears and bought a pair of 650cca (cold cranking amps) dual post batteries that were the same size. Then i cut off the top posts and screwed on the side post conversion posts. They fit and worked great with a combined 1300cca starting was no problem. I think the batteries were about $75 each (CDN).
75 targa 2.7
Lean and green
Old 08-25-2003, 11:34 AM
Platinum Member
dad911's Avatar
Brad
My Optima is at least six years old. My last Interstate lasted two years. IMO Optima is same or cheaper in the long run.
Old 08-25-2003, 11:39 AM
Double Trouble
targa911S's Avatar
exact duplicates...interstate mdl # 911-50. $100.00 each. Fit perfect. Been crankin for 2 years now.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
I've been cranking an Optima since '96, albeit not on a daily basis and with a battery tender between running. Seems to only fit on the driver's side with the larger, late model fuel tank. BTW, the shelf life (disconnected) is a lot better than wet-cell lead-acid batteries.
Try to avoid wet cell batteries that accelerate the death rate of the battery compartments/pan.
Sherwood Lee
'69 911
http://members.rennlist.org/911pcars
Old 08-25-2003, 12:21 PM
sfierle's Avatar
Thanks for all the input, I knew I could count on you!
1987 951: new toy
1971 911T: Sold
1973.5 911T: Sold
1983 928S: Sold
Old 08-25-2003, 05:53 PM
SnakeDoc's Avatar
Anybody got some step by steps for how to convert to single battery optima? It sounds like the thing to do, if it will fit the passenger side battery well.
Tom
'72 side oiler Targa:
A project, a passion, a Porsche!
Old 10-16-2004, 09:07 PM
copper's Avatar
69 T
2 Costco Kirlkland Signature #7's. 640 CCA x 2 = 1280 CCA
$52 CA each = $104
or $80 US.
Fit in the boxes. (Sideways, earthed side in)
Never a problem starting.
Jim
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 10-16-2004, 09:45 PM
lateapex911's Avatar
The Optima types (Odysey) are the way to go without a doubt!
No acid, any mounting position, one instead of two, and more power! Where's the downside?
Expense?? Not in the long run!
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 10-16-2004, 09:55 PM
Tom
No instructions needed. Get the Odessy as above.
Wrap the left side connections well and fasten somewhere.
Thats pretty much it!
If you go with the Optima, the fittment is different, on its side, pos side out. might need to mod the strap in some way, but it's pretty obvious.
Old 10-16-2004, 09:59 PM
"If you go with the Optima, the fittment is different, on its side, pos side out. might need to mod the strap in some way, but it's pretty obvious."
...or pos side in. Either way, fabricate a holddown bracket to prevent the battery from shifting and the pos. post from contacting ground.
Sherwood
Old 10-17-2004, 03:08 PM
Yeah...I did pos side out as I was considering that in the event of a right front crunch the post could get jammed in the box, short out, and POOF!
And there would be NOTHING you could do at that point to prevent a big ugly meltdown.
It should be noted that I have an RS plastic tank, so the pos post has much less to hit out there. But in either case, get a GOOD cover boot for the pos. post!
Old 10-17-2004, 03:54 PM
