front bumper trim lifting
What holds that black rubber trim down on the front bumper of a 81'?
Its starting to lift and when I look underneath the rubber is ripped and I can see the metal insert. Is it easily replaced? How much is the piece? |
There is a soft iron core that rusts, causing the smile to lift. It's not a big deal to swap them out. There are a bunch 13mm long self tapping srews that hold it on from below.
Designer King
Check w/ our host for pricing on the "Smile"
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
I have the Gerry Burger article that outlines the "smile" replacement. Let me know and I will be happy to send it your way.
1977 911S 2.7 GruppeB #036 |
