Just out of curiosity, have you swapped in a new or known good rotor and/or cap?
http://forums.pelicanparts.com/showthread.php?s=&threadid=188429&highlight=packag e also - I'd check points/dizzy operation with an ohm reading across dizzy trigger connector and engine ground as long as your in there. - couldn't you invest in CDI parts and remove them later ? - a simple points/condensor/coil back-up is doable for $20. - a CDI consists of main CD box always on power and ground, an ignition sw on/off wire, a coil, a dizzy trigger, and an rpm/tach wire. - it seems so far that it's your coil.. unless unlikely builders wiring. |
ps: he tried to manually trigger the CDI and it didn't work. |
I have tried to manually trigger two of the CDI's and both times without luck, I have all wires working, so I think its the coil. I heard some noise from the coil, which was odd. Anyway, rather than dick-around and spend money on local mechanics that probably know less about this system than I do at this point I ordered the following today:
Perma-tune CD/Coil combo Allison breakerless ignition. With these I will have I think a reasonable chance at getting her running. I am not sure about how the three wires of the current CD/Coil/Distributer will cross-over to the new set-up but I hope these items come with instructions. Anyone have experience in installing these? Thanks Dave for your input, thanks Ronnie, I know I can count on you always. Too bad you fellas dont live near here. Dave, did you make it to LA? If so make sure to come hang out with the EVIL crew next time I am out there (next month) |
James,
If you have a VW specialty shop near you ... get a Bosch Blue coil! If only Detroit iron hotrod shops around ... get an MSD High-Vibe epoxy-filled coil. Both are less than $50 ... and both will work with either Bosch or Permatune CDI boxes! |
I was told that either of these will eventually ruin the CD box because they lack a specific resistance which a properly functioning bosch coil has. Plus, if I am going to be "in there" I want to make sure it is all new when I am done. This is my only car at the moment and I need her to be reliable.
I share your thoughts on being able to have access to good shops. I am sure down there in south Texas you have simular challenges. The thing is, I really think that I'd be wasting my time with anyone other than someone who has fixed this type of issue before. So that leaves me! And with you guys to support me I hope she'll be running soon! |
James,
Bosch recommends that no other coil than the Porsche OEM coil be used with their CDI units. For years I followed that recommendation, and preached it here on this board! However, recently I tested my original Bosch CDI unit with the Bosch Blue coil, MSD High-Vibration coil, Sears Epoxy [30+ years old] coil, Bosch Red coil ... for extended tests several days long, continuously on each coil ... no failures! Whether various shop recommendations not to use any other coil than the Bosch 0.221.121.001 coil were based on the Bosch official documents or not ... I have no idea, but the fact that the Bosch coils are now over $150 may have colored their recommendations ... The primary winding resistance and inductance [and turns ratio] of the MSD epoxy coil are very close to the OEM Bosch coil, and I have no doubts or concerns whatsoever about one of them causing a Bosch CDI unit to fail! ps, The current Bosch 0.221.121.001 coil has a silver aluminum case, and is made in Brazil. It has demonstrated a very high failure rate ... and I do NOT recommend that it be purchased! Used, old OEM black German-made Bosch 0.221.121.001 or 0.221.121.006 coils can occasionally be found on eBay for good prices. |
hey Warren
Thanks for that info. I just spoke to Ronnie on the phone and I have a good idea what I am going to do when the parts come in. Just a reminder, I will have the coil-CD combo unit now so I wont need an external coil going forward. I will hold onto everything such that I have back up set-up. |
anyone have a elec diag for a 72?
James, the wiring for the CD is totally separate from the rest of the car. It only gets power from a connector on the rear fuse panel.
I can fax you the diagrams though. |
I know, I remember pal. I am just curious to have one. I want to look at the ignition switch, etc. The one thing I have not been able to test is if the CD has power while cranking.
James,
This 1971 diagram on Pelican is identical to CDI and MFI on your car ... http://www.pelicanparts.com/911/911_...971_Part-2.jpg |
thanks Warren! I really appreciate it. Before I take the rental car back I am going to pick up a timing light (sears is what I have so any recommendations?) and some outside lighting for working in the dark. I can bring the whole panel inside to mount the new CD unit and associated items before heading back out for the install. Not going to switch the points yet. Wanna see if the change mentioned will get her running.
Does anyone out there think this is the ignition switch?? |
UPDATE
FedEx just dropped off all the parts. I got a timing light at Sears this morning, the one with the adjustment thing on the back for advance, so tonight I will be putting at least the new permatune CD/COIL on, wish me luck fellas! James |
ok, well, I have a spark now. I also changed the plugs and it seems like it is trying to fire. lots of moderate little back-fires. I think that it might just have a bunch of fuel in the cyl. from all the turning over of the engine I have done.
But she still won't start. Any ideas? |
Timing? Did you pull the distributor to install the Crane trigger? If so, make sure you align the correct pulley marks on the fan housing (BTDT :D)
I have not installed the Crane. Should I do it now or try and get the old points to work?
Definately sounds like the timing is off.
ok, the question is how can I get it close enough to start? I am done for tonight. Gonna tackle it after work tomorrow. Any tips are much appreciated. Dave, I am out in LA soon, come hang out with the EVIL crew when I am there ;-)
If they were working before Id leave them until you get this problem fixed.
When you do install the trigger, make sure that the Z1 mark (TDC for #1) is aligned with the mark on the fan housing when the shutter is open or you will have a similar problem. I accidently used the full advance mark (pulley not marked and I couldnt see real well) when I installed mine and quickly flooded the engine. |
James,
Have you checked the static ignition timing? That needs to be reasonably close to TDC or slightly retarded. Yup, pull the plugs and dry them out. Put a hot-air heater under the engine. Disconnect the cold start fuel and crank the engine occasionally over an hour or so with the plugs out. Remember to keep charging the battery. Reinstall clean, dry sparkplugs. If it won’t start in the first few attempts, stop. The two choices are to repeat the above process or try some “starting fluid.” This is available at all auto parts stores, even Wal-Mart. This is “ether” and is extremely flammable. Use as little as possible, it has octane rating of 2. Once running you must first make sure the ignition timing is within the ball park. Best, Grady |
thanks. I have new plugs in the car, do I need to pull them? It seems like it is trying to start. I think it would be wise to (if someone can clearly explain via this thread) to get the timing closer. The cold start is NOT connected, I think that the car is getting enough fuel (I tried with less fuel and it was not trying to start as much as now)
I am not sure how to check that Grady (static)
James, to set the static timing, turn the engine over to TDC. The Z1 mark will line up with the mark on the fan housing and the case split. Once the marks are lined up, pull the distributor cap, rotor, and cover.
When you twist the distributor shaft, (you'll be actuating the mechanical advance) the points should go from closed to just starting to open the moment you twist it. |
I had to go back and re-read the thread. How did you ever get it to start easily without the cold start squirter? My car needs a solid 30 seconds of cranking before it will fire without the cold start squirter. Seriously, trying to start the car without the CS hooked up was a major PIA.
Are you sure its always been disconnected? Is the line off of the filter assembly plugged? Is there any fuel hose running to your throttle bodies? Here's a thread where I got a lot of help troubleshooting mine. |
ok, I will do that tomorrow and then try and start the car. In all the ****** with things it might just be too far off now. Thanks guys and especially Tyson and Ronnie for the phone support.
Tyson and I didnt get a chance to get it hooked up. Yes, it used to fire right up without it. That was before it started getting a little colder and before I f-ed up and fuel fouled the plugs, not to mention that the points wore down which all contributed to this wonderful situation I am in. That said, I have learned a ton!
so, I can use turn the motor over, align these marks, pull the distributer cap, if its not as Tyson discribed above, adjust and then the timing should be ok?
James,
Have you had the distributor out of the engine? If so, stop now and report back to us. There is another different set of steps to follow. It is possible the distributor is 180 out or other. If not, proceed. If, for whatever reason, the cylinders have way too much fuel, you must dry them out. That is the reason I suggested pulling the plugs. Even brand new plugs can easily become fuel fouled and need to be dried. Warming the cylinders and heads helps. Cranking the engine with the plugs out helps expel the excess fuel from the cylinders. An easy way to check/set the cranking timing is to put the timing light clamp-on pickup on the coil wire and crank while adjusting (rotating) the distributor to get the light at the timing mark. This gives you six flashes per two revolutions, easy to see. Even better when the plugs are out (connect a plug wire and plug to the coil and ground the plug) because the engine turns faster. The basic adjustment is at the mark while cranking. (You are using the TDC mark and the two 120 marks.) Once you have everything running and warm, set the timing at 6000 rpm to what Tyson specs. Always recheck it after final tightening of the distributor. Best, Grady |
no, I have not messed with it, other than to turn it clockwise 2 MM per Tyson, that is all. I just want to make sure that I get the points right.
thanks Grady. I dont have a remote starter and I would hate to have to pull all those plugs again... plus it seems like it is nearly starting. it is making lots of noise, baby back fires for lack of a better phrase, so I think we are close. Plus, I have not pumped the gas, or sprayed a bunch of carb cleaner in there. |
Any chance the belt that drives the MFI pump has slipped a couple of notches or jumped off track?
I dont think so since it was running fine and all the plugs I pulled out were badly fuel fouled. I think it will start if I get the timing closer and turn it over a bunch (Tyson is on board with this too) we'll see, I am nervous about the timing thing based on my lack of experience but I have been able to get this far (thanks fellas) and I also have an understanding of what I am trying to do.
James,
I’m not a fan of using carb cleaner, WD-40, etc. as starting fluid. Use only real either Starting Fluid. An easy technique for insuring the thermostat is turned off is to use a hair dryer or heat gun into the thermostat air exhaust while the engine is not running. You can use aluminum foil as an air adapter. This helps to insure you aren’t adding more fuel while cranking. Another technique for clearing the cylinders is to pop off the control rod to the MFI pump at the cross-shaft (arrow in image.) Just pop off the end at the cross-shaft and not at the pump. Insure the rod stays toward the rear of the car. That lets the pump fuel be at idle or less. Disconnect the ignition. Then hold the throttle wide open and crank for ten seconds occasionally. The reason for the open throttle is to get maximum pure air in the combustion chamber. The compression heating of the air will help vaporize the unburned fuel and pump it out the exhaust. Remember to pop on the control rod when you try and start the engine. " http://forums.pelicanparts.com/uploa...1098886255.jpg " (C) 1969 Dr. Ing. h.c. F. Porsche A.G. Best, Grady |
thanks Grady. I was able to get that rod off last night and I cranked the car over, no start, it didn't even try to. When I added the rod back (normal operation) it would then pop (small backfire as I mentioned above) and seem to show more "life". I will pick up that either today, get the air cleaner off and drop a SMALL amount into each hole and then turn it over. Before I do all of this I am going to make sure that the timing is as close as I can get it. Stay tuned fellas! Lets hope she'll run tonight.
I think what has caused this condition is as follows: 1. my office is only 1.5 miles from the house, thus the car was not getting warm before being shut down 2. without a connected cold start, and with the temps going lower in the night hours, I was having to work harder e.g. pump the gas, to get the car to start in the morning, thus (I think) building up fuel on the plugs and contributing to this (when I changed to new plugs it showed more life than at anytime before) 3. when I checked the points early in the process they didn't seem to be opening (I cranked the engine over two full cycles). Since then I have set them to open one matchbook width as per Ronnie. 4. I have modifed the position of the distributer by 2-3 MM as per Tyson CLOCKWISE (closing by that amount the gap on the right of its adjustment point) this might have contributed to the out of timing issue, not sure (see number 3) So that is why I will focus on getting the points right before trying to start it again. Since I know I have spark and with the reputation of either given here, I assume (dangerous I know) that it'll fire with the either. LETS HOPE SO! Thanks so much to all you guys, this BBS rocks! James p/s as pissed off as I am - somehow I am still having fun! the addiction to Porsche is that strong! |
James,
http://www.pelicanparts.com/techarti...djust_pic1.jpg http://www.pelicanparts.com/techarti...just_pic16.jpg http://www.pelicanparts.com/ultimate...47-reduced.jpg The proper point gap is 0.014". Matchbook cover will get you in the ballpark, but a proper feeler gauge setting would be better! I believe the timing is off by more than 20° or you wouldn't be having difficulty starting. My suggestion is to get a 12 Volt test lamp, and set static timing as follows: 1. Turn the engine over to TDC #1 with the crank pulley Z1 notch aligned vertically with fan housing notch and crankcase centerline. 2. Rotate the distributor until rotor is in vicinity of the #1 cylinder notch on the distributor body [in the pic] 3. Connect test lamp cord to a convenient fuse location ... when probe is grounded, the lamp should illuminate. 4. Disconnect trigger wire at distributor. Hold test lamp probe to distributor trigger terminal. 5. Rotate distributor body clockwise until test lamp is on ... rotate distributor body counter-clockwise very slowly until test lamp just goes out. That is a static timing point of TDC. Tighten distibutor clamp nut without moving distributor body!!! Recheck timing by turning engine over 2 complete crank revolutions by hand to see if timing is still precisely at TDC. Engine should start relatively easy at that timing setting! Any further questions about the distributor and setting the timing to factory specs should be answered by the following thread: http://forums.pelicanparts.com/showthread.php?s=&threadid=5432&highlight=distribu tor+lube |
James,
Be sure and keep a large 20#+ CO2 fire extinguisher handy. That way if you even SUSPECT there might be a fire, you can blast away and not disable the engine with powder. I am editing my above post to explain why it is important to crank the engine with open throttles. There are many who lurk and don’t ask “why.” 1) See if you can find a nice small breakfast spot 10-20 miles from home with several possible routes. That gives you a nice wake-up shot of Porsche in the mornings and lets Scruffy get some heat. 2) I agree. 3&4) It is hard to tell at this point. The points may have been an issue originally or it is possible you went down the wrong trail. One of the most difficult things with automotives (as medicine) is diagnosis. Even the best equipped shops (and medical centers) have a difficult time with proper diagnosis. Regularly skilled professional automotive technicians and physicians get lead down the wrong path. This is the main point behind Check, Measure, Adjust (CMA). You have to Check everything. You have to Measure all of the quantifiable parameters. Only then do you Adjust something and then knowing how to re-adjust back to the original setting. Sort of the physicians “Do no harm” philosophy applied to MFI 911s. It is difficult enough to identify a single problem. It is exponentially more difficult when there are two problems. This brings me back to your situation. To solve problems like this, you need three things; knowledge, tools & equipment, and a convenient place to operate (pun intended.) You should start yourself a “Scruffy notebook” that is a combination workshop manual, parts manual, notes, wiring diagram, clipped articles & threads, photos, and much more. The knowledge you learn and have available will be invaluable to you and Scruff’s next caretaker. Of course there is a huge reservoir of knowledge available on line. Basic tools and diagnostic equipment doesn’t have to be very expensive. There have been some good Pelican threads on this subject. In Southern Indiana you are going to have weather to contend with. Rain, sleet, snow in the winter; heat, humidity and insects in the summer. You need an enclosed heated, dehumidified and air conditioned garage. Tyson, James’ troubles reinforce my liking the early MFI pump front cover with both an enrichment solenoid and a shut-off solenoid. That front cover and solenoids fit all Bosch street MFI pumps I have seen. I have wired them to momentarily enable one solenoid or the other with a center-off position. Best, Grady |
thanks Warren & Grady. With that information I think I have a very strong chance of success. Although, I maintain that the timing is close enough to start (IMHO) having that verified will be great! I knew it was not 180 out because 1. you can't put the cap on that way due to the male side 2. you cant put the rotor on 180 out. So I must be close. The either will be what makes a difference I think.
So, does PepBoys have that stuff? Where should I get it as I can't recall seeing it before? |
James,
Yes, your Pep Boys should have a 12 V test light and either Starting Fluid. That is where I get mine. Starting fluid was necessary when we were racing IKF spec 5 HP Briggs & Stratton with methanol fuel. The combination of relatively low compression and cold methanol wouldn’t allow them to start cold even on a warm day. Best, Grady |
thanks Grady. It give me some confidence to know that this should help get me running. Once I get is running, will I ever be able to have confidence in it starting again??
James:
I like, with each new post, to "re-post" an outline (checklist) of what I've gone through up to the moment, for the benefit of the heavy hitters here (the Warrens, Gradys, Jims, Ronin, Lorenb, etc.,) example. 1. Battery _______ 2. Fuel delivery system ______ 3. Ignition Primary ______ Ignition switch ______ Connections secure_____ Rotor ______ Distrib. Cap ______ 4. Ignition Secondary ______ ______ 5. Etc., And go right on down a clear priority checklist for your's and the experts (not me), that chime in here. I usually look to the easy things first. One last question: What condition is your dizzy rotor in? And what condition are your dizzy contacts in? |
| All times are GMT -8. The time now is 09:02 PM. |
