Registered abUser
TerryH's Avatar
Shrapnel on the plug. Normal trans/diff wear?
I've owned the car 7 months and finally got around to changing to Swepco yesterday. It was my first attempt at changing the fluid and I will find a better way of filling the gear box next time. Those $3 hand pumps can wear a guys arm numb under the car.
Anyway, these particles were on the magnetic drain plug along with a little metal dust. Cause for alarm? Should I start saving now for the overhaul? The trans feels typical from what I've interpreted from others here, a little stiff/notchy when cold, smoother when warm, never great. No grinding or other abnormalties as of yet.
BTW... the dime came from my pocket.
'81 911SC Coupe SOLD
Old 10-24-2004, 12:19 PM
I'm not here.
K. Roman's Avatar
I changed mine with swepco last month. My plugs didn't look anything like that. Just some very fine metal dust. I'd be concerned.
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 10-24-2004, 12:27 PM
70SWT's Avatar
Usually when I see swarf from "normal" wear on a Porsche trans, the particles are much finer than that - kind of a little pyramid on the magnet. I bet you will need that trans overhaul (or replacement if more cost effective) sooner or later. For now, I would just drive it and get your money's worth out of the current unit.
2018 911 Carrera coupe
1972 911T targa
Old 10-24-2004, 12:54 PM
Irrationally exuberant
ChrisBennet's Avatar
Those bits look odd to me. Like "72" said its usually little "hairs" or a chips/teeth from the dogs. Those look more like strings of sealant or leftovers from some machining operation (drilling, milling). You said they were on the magnetic drain plug so one might assume they are magnetic. Are they (magnetic)?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-24-2004, 01:10 PM
IROC's Avatar
You should be seeing a silvery "paste" on the drain plug, not pulling chunks off...
I would be suspicious.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-24-2004, 02:25 PM
Registered abUser
TerryH's Avatar
-Chris
Yes, all those pieces are magnetic. Nothing else was there except the gray paste stuck to the plug. I suppose draining the trans again after 2,000 miles will let me know if things are getting worse in there.
The car shifts fine and I wouldn't have any reservations about driving it coast to coast.
Old 10-25-2004, 05:45 AM
