126coupe's Avatar
Dont Use Rubber Valve Stems For Racing
My rubber valve stem sheared while going into turn 1 at Las Vegas road coarse, blew the LR and flew I flew off the track while running 2nd in the Porsche / Alfa Challenge race. Looks like the centrifical force caused this failure
Any ideas where to purchase good steel valve stems??
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 10-20-2004, 02:48 PM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
I bought mine at Dimension Racing. Very happy. Take a look ...
http://www.racingdimension.com/index.asp?PageAction=VIEWPROD&ProdID=210
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 10-20-2004, 03:11 PM
126coupe's Avatar
Thanks I ordered from Summit racing $32.00 for 12
28' Pace Trailer
Old 10-20-2004, 03:13 PM
Zeke's Avatar
You weren't using the metal supports? I think a rubber VS with a support is OK. Thing is, between the two and the combined weight, you can probably buy a high end metal stem at the same weight. I dont think you want the run of the mill tire shop metal ones.
Old 10-20-2004, 05:32 PM
Wavey's Avatar
Right - you need these:
http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&uid=default&description=valve+stem+support&view_records=Click+to+View+Parts&re=on&mh=20
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 10-20-2004, 06:15 PM
efhughes3's Avatar
I posted this same thing in July after losing one of mine going into #1 @ Texas Motor Speedway. I've added the metal supports Zeke mentions. Quite an eye-opening experience and basically cost me two new tires as the one that went was destroyed due to the speed I was going when it went.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-20-2004, 06:19 PM
COLDBASS's Avatar
Go see Al, Go see Al, Go see Al... (sorry for the weak plagerization of Worthington commercial)...
Got mine from Al Reed...
923/912E (2.1l OEM EFI
'99 F150 4x4 Chipped (who cares)
LLVL in the LBC...
"Long Hoods Rule"
"RICE - The Breakfast of Champions"
Old 10-22-2004, 07:42 AM
911SCfanatic's Avatar
What exactly is the failure mode?
Bill G.
'68 911 Ossi Blue coupe
Old 10-22-2004, 07:53 AM
Friend of Warren
Any decent tire shop will carry the metal valve stems.
Kurt V
Old 10-22-2004, 07:54 AM
efhughes3's Avatar
At high speed, the rubber stems crack from being bent by centrifugal force pushing them toward the rim they come out of.
Ed Hughes
2015 981 Cayman GTS
Old 10-22-2004, 07:56 AM
Zeke's Avatar
I have seen just a couple of sources for nice aluminum valve stems. One source is on eBay, search "valve stems racing."
Old 10-22-2004, 08:03 AM
chibone_914's Avatar
I use the valve stem supports and use zipties on them. I have never lost a valve stem with this combination. Please do not use metal (solid) valve stems as they can shear easily and the small rubber gaskets have a tendency to dry out over time and begin to leak.
Thank you!
John
johnechi@hotmail.com
Old 10-22-2004, 08:12 AM
TMH TMH is offline
TMH's Avatar
Interesting points made by John, just above, when you think about the exposure of the valve stem to many things which want to break it right off. The last time I had a new shop mount some tires on my street car's Fuchs, they guy behind the counter says to me "Now you want the really short valve stems, right?" I said yes, and they are standard rubber valve stems which protrude about 1/3 as far out of the rim as the "normal" rubber VS's. Boy, with these you almost don't need the aluminum support pieces (which I am only running on the track car, which has normal length rubber VS's).
Maybe the shorty rubber VS's are the safest (supported or unsupported)?
Tom
Ain't life grand?
Old 10-22-2004, 09:10 AM
Bill Verburg's Avatar
The short metal ones are best, you do need to regularly change the seals. Tires should be replaced every 5 yrs or so even if not worn out, replace the gaskets at the same inrtervals at a maximum.
You also want to use caps w/ a gasket in them, the only ones that I have seen w/ a gasket are metal.
Don't leave them on for normal street use, JDs covet them, they have a tendancy to disappear sooner rather than later
Bill Verburg
Old 10-22-2004, 12:47 PM
304065's Avatar
May I recommend Aircraft valve stem caps. These are designed with an internal seal for high pressure use and aren't that expensive. They are bright yellow so easy to verify they are in place on the walk around.
Available from www.aircraftspruce.com
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-22-2004, 01:10 PM
Formerly bb80sc
Vipergrün's Avatar
Where does one purchase the supports from? Have not had luck finding them..
TIA
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 10-22-2004, 01:31 PM
Formerly bb80sc
Vipergrün's Avatar
Never mind....followed the link above
Cheers
-Brad
2015 Cayman GTS
Old 10-22-2004, 01:32 PM
