-   -   Help, Have Lost Indicators (http://forums.pelicanparts.com/porsche-911-technical-forum/188679-help-have-lost-indicators.html)
Fishcop 10-23-2004 03:32 PM
Hoping someone has some ideas...
I was installing my TRE "R" tailights and accidently crossed some wires in the harness I made up and blew the fuse. I replaced the fuse but they just wouldn't work. I have now replaced the blinker can behind the dash... still no luck. We're talking both sides and they were working perfectly.
Any Ideas out there?
Cheers
Early_S_Man 10-24-2004 03:54 PM
John,
Hopefully ... the blown fuse incident didn't also take out the stalk switch for the turn signals!
My suggestion is to download the SL33-lft.pdf and SL33-Rt.pdf schematics from Sherwood Lee's Rennlist page ... and print them out, then carefully go over your new harnesses to make sure the left and right tail lamp #65 five-pole connectors match the proper color code and function.
http://members.rennlist.org/911pcars/WiringDiag.htm
Fishcop 10-26-2004 09:07 PM
Thanks Warren. I traced the fault to a poor ground in the dash connection. It appears to have been butchered in the past... I will be re-wiring the section and using SOLDER instead of twisted ends and tape!
