Bird. It's the word...
Fishcop's Avatar
Help, Have Lost Indicators
Hoping someone has some ideas...
I was installing my TRE "R" tailights and accidently crossed some wires in the harness I made up and blew the fuse. I replaced the fuse but they just wouldn't work. I have now replaced the blinker can behind the dash... still no luck. We're talking both sides and they were working perfectly.
Any Ideas out there?
Cheers
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 10-23-2004, 03:32 PM
Early_S_Man's Avatar
Porsche Crest
John,
Hopefully ... the blown fuse incident didn't also take out the stalk switch for the turn signals!
My suggestion is to download the SL33-lft.pdf and SL33-Rt.pdf schematics from Sherwood Lee's Rennlist page ... and print them out, then carefully go over your new harnesses to make sure the left and right tail lamp #65 five-pole connectors match the proper color code and function.
http://members.rennlist.org/911pcars/WiringDiag.htm
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-24-2004, 03:54 PM
Fishcop's Avatar
Thanks Warren. I traced the fault to a poor ground in the dash connection. It appears to have been butchered in the past... I will be re-wiring the section and using SOLDER instead of twisted ends and tape!
John Forcier
Old 10-26-2004, 09:07 PM
