Rims On 77 S
HI GUYS FIRST POST NEW OLD CAR.
WHAT TO DO?WHEN I BOUGHT THE CAR IT HAD 15"FUCHS ON SO I CHANGED TO 16 6S&7S .PROBLEM IS AS YOU PROBABLY KNOW IS THAT THE REARS RUB TIRES ARE 225 55 16 I LOVE THE LOOK BUT I AM WONDERING IF I WOULD HAVE THE SAME PROBLEM RUNNING 6S ALL ROUND OR WOULD 15 6S AND 7S WORK IF SO ,WHICH WOULD LOOK BETTER. PLEASE HELP$SLEEPLES IN TORONTO! |
19 years and 17k posts...
Martin,
I have a '74 "narrow body" with 6jx15 Fuchs on the front with 205/60/15 and 7jx15 with 205/60/15 on the rears with no problems! I had rubbing on the rears when I tried 8jx15 with 215/60/15. The rubbing only happened when I had the kids in the back seat. Hope this helps!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
First , please lose the all caps, it's really rude
Second, 225/55x16 is wrong for any 911, 225/50 x16 can be made to work on 7s or even 8s(either needs+23.3mm o/s) if you want to do a lot of juggling of ride height, camber, lips etc.
My '77 narrow body has 6x15" 205/55 front and 7x15" 215/60 rears with 22/28 t-bars and negative 1.5 rear camber with no rub. I've rolled the fenders slightly in the rear.
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
Sorry for the caps thing .It was 9 in the morning here and I was half asleep. no offense.The rear size is 225 50 16.
Designer King
Welcome. If you search you will find info on rolling the fender wheel arches to allow more clearance. You will also find info on ride heights.
Where are you located in Toronto?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Pickering actually.thanks Paul
A really useful tool is
Search here is a short list of results from searching "narrow and rims" Photos of 15x8s on my narrow body '74 anybody running 225/50 15" on front of narrow body ? Cookie Cutters rims, will they fit? Add flares or not ? whhels/tires for a narrow 911 it goes on and on
What looks better,16 6s all around or 15 6sand 7s ?lease help!
I would try to make the 16s that you have work. Those of us with 15s are finding it harder to get decent tires.
Mike Searching for a new ride '04 VW GTI 1.8T RIP ![]() '76 911S 3.0 RIP ![]() http://www.pelicanparts.com/gallery/BanjoMike |
