ausgezeichnet's Avatar
What is a jumper?
I understand to set idle speed correctly you need to by pass the ICV by jumpering test ports (B & C). This might sound silly, but what is a jumper? Is it just a peice of wire or is it a tool you have to purchase. If it's just a peice of wire, what guage should it be? Thanks.
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 10-24-2004, 10:25 AM
Send a message via AIM to fintstone
A piece of wire. Normally the same gauge or larger than the wire connected to the pins you "jumper."
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 10-24-2004, 10:34 AM
Irrationally exuberant
ChrisBennet's Avatar
That picture looks familiar. For the test port I just fold up a paper clip so the ends are doubled back on themselves so they fit in the holes but have a enough springiness to stay in place by themselves.
A "jumper" is just a wire used to make a (usually) temporary connection.
Usually there is something on the ends to facilitate connection. A jumper for the fuse box would have alligator clips on the ends for example. A jumper for disabling an alarm would have a of spade connectors on the end.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-24-2004, 11:09 AM
Registered abUser
TerryH's Avatar
A suicidal man atop the Empire State building.... oops, wrong kind of jumper.
'81 911SC Coupe SOLD
Old 10-24-2004, 11:51 AM
Got it! Thanks.
Mike
'83 911 SC Coupe
Old 10-24-2004, 11:53 AM
