Designer King
Paulporsche's Avatar
Where do I hit the starter?
I've checked Wayne's book, Mr Thoruson's article in the tech section and looked in the exploded views, but I can't find a good picture. I want to give the starter a few whacks to see if I can free it up before I go and remove/ clean/replace it. When starting, the starter lately sometimes makes either a grinding noise or a ZZZZZZZ noise and fails to engage. Other times it will start normally.
In reaching under the car, do I look on the passenger side, about even w/ the rear wheel? Should I give the body of the thing a few hits w/ a hammer?
Can someone post a picture?
I realize this may not be the cure, but I thought I'd try it first.
Thanks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-24-2004, 01:09 PM
VincentVega's Avatar
Anywhere really. Best done from underneath, maybe use a long extension to get better aim at it.
Old 10-24-2004, 01:19 PM
I would rather be driving
jpnovak's Avatar
If you hear it spin but no engagement then the plunger on teh solenoid is sticking. Look for a smaller round canister on the top corner of the starter. This is what the wires attach to. To be honest, its only two bolts to remove the starter. Its easy to disassemble and clean. Saves you from having to bump the solenoid.
Old 10-24-2004, 01:54 PM
You do not have permissi
john70t's Avatar
Better get to it right away, else it`ll be a required engine drop and a new ring gear. A new high-torque isn`t that much, improves reliability, and cheaper than a tow.
Or just park only on hills
Old 10-24-2004, 08:04 PM
Designer King
Just to follow up, I replaced my old 173,000 mi starter w/ a new high torque Bosch rebuild. No more starting drama.
Paul
Old 11-01-2004, 06:06 AM
try cleaning electrical connection first. You may not have full current.
1984 911 Euro Cabriolet
1988 928 S4 with Murf Supercharger S1
Old 11-01-2004, 08:56 AM
DavidI's Avatar
As was said earlier, the starter is made up of 2 major parts: the drive motor (which spins your motor) and the solenoid (which extends and retracts the drive gear). If you hear the whizzing noise, your drive motor is good, but the solenoid may have failed. If you hear the clicking noise, your solenoid is working, but the drive motor has failed. As was said earlier, check your wire connections first.
Good luck, David
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 11-01-2004, 09:47 AM
