MFI part #S
Does anybody have a listing of part #s for MFI stacks, throttle bodies and injection pump for 2.4 T thru S.
Thanks, Joe |
Look in Check, Measure Adjust for the pump part #'s.
Here are the pump numbers. They are from page 44 of Check, Measure, Adjust. As John mentioned you should get a copy of CMA, which you can download from the link in my signature area.
http://forums.pelicanparts.com/uploa...1098911365.jpg |
thanks Derek, anybody have #s for stacks and/or throttle bodies?
thanks, Joe |
For the 2.4 years, S and RS were the same for stacks. Not sure about TB's...so when parts shopping, check numbers for each...
2.4T L-TB 911.110.081.10 R-TB 911.110.082.00
2.4E L-TB 911.110.083.10 R-TB 911.110.084.00 Stack 911.110.065.02 2.4S, 2.7RS L-TB 911.110.085.10 R-TB 911.110.086.00 Stack 911.110.063.02 The T-E USA engine was an afterthought that was not completely documented in the parts catalog! |
Warren, thanks for the info. Just wondering if you have any inputs on what I'm trying to do. I've just pulled the motor and will begin teardown this weekend
-2.4T motor (not sure of condition of Ps&Cs yet) - addition of E stacks and TBs -Cams ? -stock heads(still not sure whether they are 32mm ports or not) some people say 30 waynes book says 32 - stock T injection pump ? Thanks, Joe |
| All times are GMT -8. The time now is 12:52 AM. |
