Details on the RUF SCR?
Anyone have more info on these cars?
This is the majority I have pulled off the Internet. Quote:
![]() Porsche 911 SCR Ein RUF im 50 Jahre Jubiläumsmodell Bj. 1981, ca. 220PS aus 3,2ltr. !!Einmalig!! 911 SCR - RUF, BJ. 1978, 220 PS, 3,2 , 17" Felgen, Heckspoiler Turbo, Domstrebe, Überrollbügel, 277.000 KM DM 28.000.00 (anyone care to translate) This translated from a German wed site: http://translate.google.com/translate?hl=en&sl=pt&u=http://www.mundoporsche.hpg.ig.com.br/911src.htm&prev=/search%3Fq%3Druf%2B911%2Bscr%26start%3D10%26hl%3De n%26lr%3D%26sa%3DN Quote:
http://shop.ruf-automobiles.com/english/catalog_rufautos.ruf Anyone have more details on this early RUF car they would like to share?nyone |
I believe the SC Ruf cars pre-dated what the Porsche factory did when they went from 3.0 to 3.2 liters.
RUF essentially went to a 3.2 liter displacement ( can't recall if it was closer to the 98mm/short stroke combo...likely...or the long stroke that the factory ultimately went with). These early cars put Ruf "on the map" long before he went to modify Porsche's turbos....as I recall. Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Thanks Will. I had thought Ruf was doing the 3.2 short stroke aka Max Moritz 98s as Bruce Anderson mentions in his book. Looks like he started offering the SCR conversion in '78. The date on the converison mentioned above (info from the engine building forum) was done in 1986 and would have the light Carrera 3.0 crank I would think making it a 3.2 short stroke.
Does anyone else have info about the Ruf SCR?
Mikael |
Hilbilly Deluxe
Ruf used to have some information on their web site. Thanks to the Wayback Machine we get this:
--------------------------------------- 911 SCR ![]() The need to reduce fuel consumption along with stricter emission laws had become one of the automotive industry´s most urgent issues in the 1970s. To adapt to these new standards, Porsche reduced its normally aspirated 3.0 litre flat six to 180 hp. Apart from the expensive Turbo, this opened a gap in the model range as customers who desired more power now had to go for the comfortable 928. Consequently, the 911 SCR conversion´s centerpiece is the SC engine enlarged to 3,185 cm³ with a peak power of 215 bhp at 6,000 rpm. The RUF five-speed manual transmission contributes to significantly improved fuel efficiency. Along with better tractability, the SCR´s road performance nearly matches the Turbo and perfectly closes the gap Porsche left open for political reasons. Introduced in 1978, the 911 SCR, together with the RUF Turbo 3.3, completed Ruf´s model range of optimized conversions of both the Carrera and Turbo. Technical: (this was in a table, so I reformatted it) Power Output (DIN) 158 kW (215 bhp) at Engine Speed 6,000 rpm Specific Output 49.6 kW/L (67.5 bhp/L) Displacement 3,185 cm3 Compression Ratio 9.8 : 1 Engine: * Air cooled horizontally opposed 6-cylinder * Longitudinally rear mounted * Chain driven OHC per cylinder bank * Mechanical Bosch K-Jetronic fuel injection system * Bore x Stroke of 98.0 mm x 70.4 mm * Eight main bearing crankshaft * Dry sump lubrication system * Electric fuel pump Transmission: * Rear wheel drive * RUF five speed manual * Single plate dry clutch * Limited-slip differential, 80% Performance: * Top speed of 255 km/h * 0 - 100 km/h in 5.7 sec * 0 - 200 km/h in 23.7 sec Tom |
Pretty much whar the factory offered as a "3.2 Carrera" starting in 84...
Wil
Do I dare ask how much those sports seats go for?????
