450knotOffice's Avatar
Question Cab top (manual, not electric) seems a bit skewed off-center
Ok guys. I've done every conceivable search looking for some info and haven't found any yet.
I've got a manual Cab top that's in pretty good shape. However, when you look at the car head-on it becomes apparent that the top is skewed slightly left. Therefore, it seals to the left side windows very tightly and, conversely, doesn't seal to the right side windows at all. In fact there is about a 1/8-inch gap to the right side windows. The latches don't seem to have any problem grabbing onto the top and pulling it down snugly.
So the question is this: is there any way to adjust the cab top so that it comes down perfectly centered on the windshield? Are there any adjustment bolts or turnbuckle assemblies down in the hinge mechanism underneath the rear interior side panels? It seems to me that the tops must be adjustable - trimmable, if you will, since no two chassis are exactly alike and neither are any two cab tops.
Can anybody help me here? Anyone?
Old 10-28-2004, 03:30 PM
yes if the top only seems crooked at the front, the two locking pins screw in and out to obtain a better seal.
Old 10-28-2004, 03:37 PM
Thank you. I'll see what I can do about that.
-Scott
Old 10-28-2004, 03:52 PM
I took some pics:
Left side:
Right side:
I'm still not sure what you mean by screwing the locking pins in and out.
-Scott
Old 10-28-2004, 04:31 PM
bump
Old 10-28-2004, 07:39 PM
doozer's Avatar
Looks like you need to adjust the centerline of your latches?
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 10-28-2004, 08:22 PM
That's an idea.
Thanks.
Old 10-28-2004, 08:24 PM
3.2 CAB's Avatar
Are the 2 pins on the front underside of the cab top, going in the windshield frame holes easily? It really does look offset. Has this always been this way, or is this something new, that has just started?
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-29-2004, 04:41 AM
They go in fairly easily but I noticed today that the "safety" latch on the right doesn't "click" when you pull it down tight. The left side does. However, the main latches on both sides work fine.
Old 10-29-2004, 09:24 AM
I think I might be making some progress here. I just went out to the garage and unlatched the top. I then pulled it down and held it as if I were the latch and noticed that the top was symmetrical on both sides. But when I engaged the latching pins slowly, the whole top moved to the left as the latches engaged. So it appears that either the latches are slightly off center or the latch holes in the windshield frame are slightly off (doubtful).
Has anyone on this board taken apart the front part of the top and seen what the latches look like in there? Are they adjustable. After looking at the situation carefully, it appears that if I could move both latches laterally slightly to the left, maybe 1/4-inch or so, the top would snug down properly.
-Scott
Old 10-29-2004, 09:34 AM
