FunWithMy911's Avatar
Question Starter Motor Whines but no crank?
When I turn the ignition on the starter motor sounds like its going, like a wheering sound, but engine is not being cranked over, standing voltage is a healthy 12.5 V, what do I check next?
(1988 930 Coupe)
Old 10-13-2004, 10:16 AM
Friend of Warren
sounds like the starter is sticking or the solenoid is no longer working. Get under the car and find the solenoid on the starter. Give a whack on the side of the starter with a hammer and see if that unsticks it.
Kurt V
Old 10-13-2004, 10:28 AM
Nup, didn't work, any other thoughts?
(1988 930 Coupe)
Old 10-13-2004, 11:21 AM
Friend of Warren
If you are sure the starter is spinning, but not engaging, time for a new solenoid.
Kurt V
Old 10-13-2004, 11:23 AM
scottb's Avatar
What kind of voltage do you get with a load on the battery? Can you attach a voltmeter on long cables and see what kind of reading you get while cranking the engine?
1984 Targa
did you do a load test on the battery ???
Start with basics then move on to next step. Next will be the starter itself: if you jump directly juice to starter, do you get same result ???
Truly, filou.
Old 10-13-2004, 06:53 PM
that sol is a tight clearance fit.. I guess if your going in to clean you might as well get a new one. Contacts do get dirty over time. I'd check the linkage as long as your going in there.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-13-2004, 10:29 PM
Thought I'd fill you in on the cause - Simply a poor connection, had enough grunt for solenoid but nothing else.
Thanks for all your suggestions.
(1988 930 Coupe)
Old 10-30-2004, 03:38 AM
