-   -   Relay question (alarm) (http://forums.pelicanparts.com/porsche-911-technical-forum/189799-relay-question-alarm.html)
kees 10-29-2004 11:38 PM
How do I make a starter kill?
This is what I read :
http://forums.pelicanparts.com/uploa...1099118048.gif
and this is what the installer tells:
86 to alarm output
87A to ingnition
30 to starter motor
85 to ground
How do I find out if a relay isn't broke?
Please help.
Thanks,
Kees.
piedogger 10-30-2004 12:11 AM
It depends if your alarm has pos. or neg starter kill output. The one in the picture is for neg. out. The other way would be pos. out. To test relay hook up pos. to 86 and 30, touch ground to 85 and you will hear it click. With no ground 87a will show 12 volts, with ground 87 will show 12 volts.
To test what you have just arm the alarm (might need to be set off) and with a meter check to see if it is putting out ground or 12 volts on the starter kill output.
kees 10-30-2004 08:27 AM
Hi Piedogger,
Thank you very much.
Kees.
