audi2.7t's Avatar
made some interesting discoveries..
While stripping the 911 down I made the following observations :-
1.B&B *exhausts are a piece of garbage . *edit..mufflers .
2. The heat knob above the e-brake has four positions --> off ,1 ,2, and 3.....#1 has no function whatsoever !! ,there are only two micro switches which work on cams ,neither switch is moved untill position #2 !!..........why bother ??.
3.It is physically impossible for anyone larger than an oompha-loompha to sit in the rear seats
4. The doors don't actually fit into the body ,they are essentially straight lines on the outside of a circle .
5.The rear grille mounted condensor is not practical for an air cooled engine that needs high air flow in a somewhat sealed engine compartment .
6.What the hell were they smoking when the thought of a horizontally mounted oil filter ?.
'96 Dodge Viper
'09 Maxima
'05 zx10..(0-100-0 before your turbo even spools!!)
'99 Rottweiler
'08 Cane Corso
Old 11-01-2004, 07:10 PM
Me like track days
Craig 930 RS's Avatar
B&B headers very nice. Heaters boxes surrounding them not good.
B&B mufflers cr*p.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-01-2004, 07:15 PM
kqw kqw is offline
# 1 works on mine just fine.
The air flow to through the condensor: The lid needs to be sealed correctly before the condensor works efficiently. I know, I used to live in Arizona and we became experts on efficient A/C operation.
Regards
The Fox
Carrera
Old 11-01-2004, 07:16 PM
"6.What the hell were they smoking when the thought of a horizontally mounted oil filter ?."
Improved air flow for the "cool collar".
Jim
Old 11-01-2004, 07:27 PM
Bill Verburg's Avatar
The designer had stock in a rag company?
Bill Verburg
Old 11-01-2004, 07:39 PM
"2. The heat knob above the e-brake has four positions --> off ,1 ,2, and 3.....#1 has no function whatsoever !!"
I'm glad that I'm not alone in this observation. What's up wid dat?
"3.It is physically impossible for anyone larger than an oompha-loompha to sit in the rear seats"
I have a 9 yr old oompha-loompha and a 12 yr old oompha-loompha, but the big one has had enough.
But I did once cram my 6 ft boss into the back seat. She was OK with it until I slammed her head against the roll bar on a fast turn. Oops, sorry boss.
-Steve
'87 Carrera Targa
Old 11-01-2004, 07:51 PM
Jeff Alton's Avatar
Oil filter..... have you seen the one on a 944?!?!?! It is upside down!!
Jeff
www.turn3autosport.com
Old 11-01-2004, 08:31 PM
Just what is so wrong with a horizontally-mounted filter on a dry-sump car ??????
Drain the oil...wait.....screw off filter with a small rag under the lower corcumference. There isn't one car that doesn't have *at least* this potential for schmutz....and some others are a lot worse.
Much worse, INHO....is the teeny, tiny, motorcycle size filter on my Corolla....located where?....yep, right under the exhaust manifold shroud. There, I always have a "hot" time and the chances for leaks alongside the engine block...no way to put a pre-emptive rag under the filter...you can only clean up the mess "afterwards"....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-02-2004, 08:58 AM
Me like track days
The 911 filter is the easiest to access and the easiest cleanup of the 4 cars we own.
Old 11-02-2004, 09:08 AM
Platinum Member
dad911's Avatar
Re: made some interesting discoveries..
You have obviously never had to change distributer points on a Chrysler slant six. Or pump gas on a car that had the filler behind the rear license plate. Guaranteed to spill 1/2 gallon of gas every time. And was it the '69 Camaro that it was impossible to change a few spark plugs?
I'll take my 60's design oil tank/filter over the 60's (or 70-90's) Detroit engineering any time.
Old 11-02-2004, 09:19 AM
Kantry Member
oldE's Avatar
Last year I provided the "Prom Night" ride to the offspring of a couple of friends of mine. Because of her dress, she got to ride in front. Despite the fact he was over six feet, we put the passenger side seat all the way forward and with a large shoehorn, popped him into place for the mile or so to the school. (We did a test fit the week before the dance to make sure.) He said he didn't mind, but I don't imagine he wanted to be back there much longer than 5 minutes. ;-)
Les
Best
Les
Old 11-02-2004, 10:11 AM
Ah the memories.....
Bill Verburg
Old 11-02-2004, 12:40 PM
Me like track days
The plugs on my '66 Dodge Dart slanty 6 were a PITA to get oil sealed correctly
Old 11-02-2004, 12:43 PM
And a b*$^h to get off/on. Lots of junk in the way. At least when you pull it off most of the oil has drained but what has not ends up dumping all over the steering pump and gravel guard. Worse is it is impossible to fill the filter before reinstalling as I like to do. The 911 was a piece of cake in comparison.
gary
Old 11-02-2004, 02:20 PM
