911mot's Avatar
What is this Bilstien tool for?
I was having a sort through my toolkit and found this:
Can anyone tell me what it's for?
Many thanks for your input
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 09-07-2004, 05:23 AM
Looks like it goes to the jack.
Neil
'73 911S targa
Old 09-07-2004, 05:25 AM
Original Owner
tsuter's Avatar
Some guy had a factory jack failure so he saved that piece. Figured he could shove a square pipe on it and maybe JB Weld on a 3-4 inch round plate and he'd have a home made jack plate.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 09-07-2004, 05:30 AM
djmcmath's Avatar
It's useful now for self defense. If you get assaulted while you're in your Porsche, you can club down your assailant with this genuine German-engineered Bilstein PDT (Porsche Defense Tool).
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 09-07-2004, 06:39 AM
Senior Member
Slide the left end inside the jacking point on the car and the other end should attach onto the jack. Without having it in my hands cannot tell if its broken or just come apart.
Early jacks were made by Bilstein...
JoeA
Old 09-07-2004, 07:51 AM
Par911's Avatar
It's a piece of the POS factory jack. Toss it and buy a bottle jack to keep in the 911.
Old 09-07-2004, 08:53 AM
Me like track days
Craig 930 RS's Avatar
Its also a sure way to have your 911 fall on ya - recycle it and have it made into tin cans, which serve a more useful purpose
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 09-07-2004, 10:32 AM
Somatic Negative Optimist
Gunter's Avatar
Weld a big nut at the end that does not slide into the sqare jacking point on the car. That way, you can use a standard floor jack and the welded nut will prevent the jack from slipping.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-07-2004, 10:44 AM
911mot's Avatar
Thanks for the replies.
I'll convert it to use with my tolley jack.
On the subject of jacking (ish), I need to replace the steering rack and have seen a pic somewhere of the complete front end removed. Will it be OK to support the car (with axle stands) on the chassis rail that runs transveresly across the front of the car, to which the A arms are bolted to?
1984 3.2 Carrera
Old 09-07-2004, 11:05 AM
911mot's Avatar
1984 3.2 Carrera
Old 09-07-2004, 11:08 AM
Senior Member
Why not use the two lugs built into the frame up front where the towing eyes are located? Thats where mine is sitting right now.
Joe
Old 09-07-2004, 11:33 AM
Senior Member
Jdub's Avatar
I support the front end using the body sections directly behind the front wheels, just inside the seams. You will find a semi-triangular area there that is ideal for this work.
John
'78 Targa in Minerva Blue
Old 09-07-2004, 11:37 AM
Original Owner
tsuter's Avatar
I can't resist! What the heck, just use 2x4s. Saw this earlier on jacking techniques.
tsuter
Thaaaats Right!!
Old 09-07-2004, 12:53 PM
HarryD's Avatar
This method is approved ONLY if you are welding near the gas tank
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-07-2004, 08:34 PM
Cool! How long did he live?
Old 08-24-2005, 09:28 PM
Brother's Avatar
He's actually welding the gas tank.
He died before the person taking the picture had time to turn around and say "Dumbas"....BOOM!
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 08-24-2005, 09:35 PM
