Question Electrical question - pin connectors
Well after much looking I still haven't figured out where my backup light wires running to the transmission are; wherever they are they aren't on the car. In fact they aren't even in the wiring loom, as I checked pins 5 and 6 on the 14 pin connector and there are no female connectors coming off the box. So I need to run wires; does anyone know what size female connector I will need coming off the 14 pin box and what size male connector I will need to plug into my backup light switch on the transmission?
Thanks in advance,
Grady aka plain fan
66 912 - enjoying the good life
78 911 SC and 90 C2 turbo look cab - gone but not forgotten
01 996 TT -
09 Audi A4 Avant - daily driver
Old 11-13-2004, 03:42 PM
Pelican sells a 14pin rebuild kit.
I guess you found the tranny back-up light switch? The sw has 2 females . the plug has 2 males.. don't know what size?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-13-2004, 05:48 PM
Ronin, do you have a part # for it? I've searched but can't find.
Grady aka plain fan
01 996 TT -
Old 11-13-2004, 06:34 PM
this should be it.. plastic cover and pins that must be soldered
PLUG SOCKET
- This is a special-order, non-returnable, part
(availability and shipping charges may vary).
OEM-91161211305
$38.07
confirm with pelican
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-13-2004, 06:49 PM
Early_S_Man's Avatar
Porsche Crest
Grady,
Should be pins #5 Green/Yellow and #6 Green wires at the 14-pin connector as shown below:
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-13-2004, 08:37 PM
