-   -   Help decoding an engine number (http://forums.pelicanparts.com/porsche-911-technical-forum/191094-help-decoding-engine-number.html)
mikequig 11-06-2004 05:01 PM
I looked at a motor for sale today, it was purportedly a '70T 2.2 liter. The Zenith carbs were there, but it had a red shroud, not yellow as I thought it would be. The engine number was 6539077 so it should mean "6" for 6 cylinders, "5" I can't figure out because my book only shows 1,2,or3 for T,E, or S The "3" should mean it's a '73 motor, and the "9077" is it's consecutive production number. So the question is what's the "5" signify?
Thanks, Mike Quigley
Jimmy_43 11-06-2004 05:27 PM
On Pg 51 of "Original Porsche 911" The engine number is listed w/ 1973 911T Sporto, under engine 911/67, under gearbox 905/21, with engine #'s 6539001 - 6539197. Maybe this helps...
mikequig 11-06-2004 05:31 PM
Jimmy, So since this is a manual trans car, it likely received this motor as a transplant for a defunct original 2.2 I presume.
Thanks for your help.
Mike Quigley
