mikequig's Avatar
Help decoding an engine number
I looked at a motor for sale today, it was purportedly a '70T 2.2 liter. The Zenith carbs were there, but it had a red shroud, not yellow as I thought it would be. The engine number was 6539077 so it should mean "6" for 6 cylinders, "5" I can't figure out because my book only shows 1,2,or3 for T,E, or S The "3" should mean it's a '73 motor, and the "9077" is it's consecutive production number. So the question is what's the "5" signify?
Thanks, Mike Quigley
Old 11-06-2004, 05:01 PM
On Pg 51 of "Original Porsche 911" The engine number is listed w/ 1973 911T Sporto, under engine 911/67, under gearbox 905/21, with engine #'s 6539001 - 6539197. Maybe this helps...
"Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid across the line broadside, thoroughly used up, worn out, leaking oil, shouting GERONIMO!"
Author Unknown
Old 11-06-2004, 05:27 PM
mikequig's Avatar
Jimmy, So since this is a manual trans car, it likely received this motor as a transplant for a defunct original 2.2 I presume.
Thanks for your help.
Mike Quigley
Old 11-06-2004, 05:31 PM
