What?!?!
DonDavis's Avatar
My Fuel Pump is Cracked. Recommendations?
Got my car running last weekend and then discovered I have fuel leak . The crack is at the base of the electrical connector.
My question is do I have any options on a replacement? Is there a "better mousetrap" so to speak? I would assume I should stay stock.
Inquiring minds want know!
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 11-06-2004, 01:09 PM
Grady Clay's Avatar
Don,
Buy the exact Bosch replacement fuel pump. There is nothing better.
Use the opportunity to clean your fuel tank and screen filter. Replacing fuel hoses is also worthwhile. Use OE type hose clamps, not the domestic worm-gear type.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 11-06-2004, 01:47 PM
What?!?!
DonDavis's Avatar
Thanks Grady! I also need the metal tray that it rests upon. The forward rubber mount was broken and the pump was moving around a bit. I'll also check the other items you mentioned.
Thanks for the quick response!
Old 11-07-2004, 09:14 AM
19 years and 17k posts...
azasadny's Avatar
Don,
Replace the rubber mounts too, PP has them. Replace all hoses and clamps (I used some stainless steel clamps from McMaster-Carr). You'll be more confident of the results if you replace all old stuff with new.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 11-07-2004, 05:39 PM
when working on the fuel system and brake system, while you are in there syndrom is a very good thing!!!
76 Targa patched 2.7
I have severe while-you-are-in-there-itis.
Old 11-07-2004, 06:38 PM
What?!?!
DonDavis's Avatar
Art,
Are those mounts separate? I though it looked like one assembly. Its still together and I'm soaking with PBBlaster. If I can clean up the resting plate and put on new mounts, that will be easy.
I found a used replacement pump from a fellow Pelicaneer. Should be able to get it back running in a week. I hope.
Old 11-08-2004, 08:57 AM
