Correct/Easy way to remove brake pad material.........???
I have a new seat of Porterfield R4S brake pads. I thought I would be fine with 17mm rear pads on my rear c993 calipers and 930 rotors - but the fit is too tight and I need to remove 1-2 mm of material so I don't overheat - You can feel them grabbing from a roll.
So, any good way to remove the material? I tried driving a few miles - but they just got hot. Any suggestions? Anybody produce a 15mm pad? |
I know I know - just drive them, right?
Belt Sander.
Disc Sander Good luck, David Duffield |
As i've pointed out many times the pad thickness varies from one manufacturer to another. |
yes you have
| All times are GMT -8. The time now is 05:01 AM. |
