MBruns for President
Correct/Easy way to remove brake pad material.........???
I have a new seat of Porterfield R4S brake pads. I thought I would be fine with 17mm rear pads on my rear c993 calipers and 930 rotors - but the fit is too tight and I need to remove 1-2 mm of material so I don't overheat - You can feel them grabbing from a roll.
So, any good way to remove the material? I tried driving a few miles - but they just got hot. Any suggestions? Anybody produce a 15mm pad?
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I know I know - just drive them, right?
Belt Sander.
Disc Sander Good luck, David Duffield |
As i've pointed out many times the pad thickness varies from one manufacturer to another.
yes you have
