Angry License Plate Bracket Install Help
'79 SC came without a front license plate frame bracket. Picked up the bracket, 4 "spped nuts" and 4 screws from Porsche Parts, but they had no diagram on how to install.
From comparing it to the car, don't see where all the parts would be used.
Anyone have a photo or diagram (or good description)?
1978 911SC (not black, Mocha Brown)
Old 11-12-2004, 04:09 PM
Mine front valance has 2 rectangular holes in it. There are spring metal pieces that snap into the holes. Sorta like speed nuts but different. I think there is a big rubber washer that goes between the bracket and the valance. The screws are 2 sheet metal screws with hex heads.
My guess is this setup will last a little longer than just bolting the bracket on the valance.
Do you have the rectangular holes?
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 11-12-2004, 05:53 PM
Yep, two holes with plastic inserts-to accepts screws I presume. The holes in the valance mate up with the holes in the wider part of the central support.
Here is what the parts counter gave me:
Old 11-12-2004, 09:32 PM
Simular looking speednuts go into the valance except I think their bigger.
Mine had plastic speed nuts for the license plate screws.
So I think you need 2 speed nuts, bolts /screws, rubber washers
They should be able to show you the picture when you go back.
Luck!
Bill Miller
81 Targa Guards Red
Old 11-12-2004, 10:34 PM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest license plate bracket
Hope this will help.
BTW This is an euro license plate bracket.
Kees.
Old 11-13-2004, 06:07 AM
