RETIRED
Joe Bob's Avatar
Worn slotted rotors....
My ATE rotors that have the atomic symbol looking slots on them are getting worn.....can they be turned and then reslotted?
2012 ML350 3.0 Turbo Diesel
Old 11-09-2004, 04:42 PM
Navin Johnson
TimT's Avatar
I replace the slotted rotors when they wear to the bottom of the slot
'69 911 GT-5
'75 914 GT-3
and others
Old 11-09-2004, 04:46 PM
RETIRED
Joe Bob's Avatar
OK...but are the rotors if the slots, areused as a semi wear indicator...out of spec?
Old 11-09-2004, 05:01 PM
jeff1hughes's Avatar
slots or not, get a micrometer and measure the thickness of the rotor. If in spec, you're set, you should have no problem turning them, though it should be done with fine cuts at a very low speed. Be sure to remeasure the rotors, or pay attention to how much is being removed, to make sure they are still in spec once they are cut and true.
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 11-09-2004, 06:29 PM
RETIRED
Joe Bob's Avatar
Yeah I can do that...just wanted to know if users of ATE Power Slots have found that when the slots are gone if they are still within spec or not....
BTW...what is the the spec for an SC front rotor?
Old 11-09-2004, 06:31 PM
Bill Verburg's Avatar
The spec for oem 20mm rotors is 18mm(-1mm/side), the machining limit is 18.6mm(symmetric)
lateral runout is <0.05mm
one would have to assume for lack of more information the same spec for aftermarket rotors.
Bill Verburg
Old 11-09-2004, 07:24 PM
