GAFB
Common fasteners to forget, which cause you to swear and curse trying to figure out why the case won't split: -The 3 13mm nuts behind the flywheel -The 1 15mm nut at the bearing saddle in the timing chain area -Each and every perimeter nut (I usually miss one the first time around) You'll also have to liberally apply your rubber mallet!
Several BMWs |
Who is H.G.P.?
Now it makes 2-46 and 2-47 quite clear. 1. Incidently, what is the engine apparently sitting on in 2-45 and 2-46? 2. Can I do everything with this adapter ring http://www.pelicanparts.com/catalog/images/Tools_folder/enginestand-mainely.jpg as the yoke? What's the difference(s)?
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche Last edited by H.G.P.; 11-11-2004 at 12:21 AM.. |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
