PorscheGuy79's Avatar
Winter Oil Question
Im heading out tonight to buy some oil for a change on my 79 SC. What do you guys suggest for Chicago climate? 10W-30? Im using synthetic brand because the PO had the Jiffy-Lude or what not sticker on there that said they were using synth with no oil leaks. I just wondering what would be the best weight for the winter months.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 11-12-2004, 03:29 PM
Bill Verburg's Avatar
I would use M1 15/50 it flows very well even at well below zero F
Bill Verburg
Old 11-12-2004, 03:37 PM
Somewhere in the Midwest
MotoSook's Avatar
How about 0W-40? You are going to be driving that car during the winter. It can get down right cold at night sometimes here..15/50 would be OK, but you won't need the topend protection durign the winter, so might as well go for good bottom end protection to help your start up. The 0W-40 has a pour point of -54F.
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_0W-40.asp
Old 11-12-2004, 03:43 PM
Thanks Souk, you're there in the clutch my friend. Heading out right now for some 0W-40
Matthew
Old 11-12-2004, 03:56 PM
anthony's Avatar
The pourpoint for 15W-50 is -45. I think either would be fine but if the car isn't parked outside all night I'd stay with the 15W-50.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 11-12-2004, 03:59 PM
MotoSook's Avatar
Why?
Old 11-12-2004, 04:03 PM
anthony's Avatar
Assuming both oils are sufficient for startup then I'd rather have the heavier oil in an air cooled engine.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 11-12-2004, 04:11 PM
MotoSook's Avatar
I've got 20/50 dino oil in my Carrera, and it's 50 degrees out today. My oil never got hot enough to open my T-stat. I doubt that the oil will get hot enough in Matt's car to open his t-stat when he's out driving around in January when it's -20 degrees out (with a front mounted cooler!). Hence my suggestion that low temp protection is better than top end protection. Why not give the oil pumps and the bearings the greater advantage. Correction...it's 54 deg. C (!)...
Is 0W40 more expensive than 15W50? And the flash points are about the same...~230 deg. C.
It's really splitting hairs, but Matt is a smart kid...he can choose.
Old 11-12-2004, 04:20 PM
I cleaned out Autozone of their 0w-40, I think thats gonna be the better option. My temp gauge right now doesnt get out of the 7 oclock postion so I think a little more heat wont be too much of an issue.
Matthew
Old 11-12-2004, 06:28 PM
Plus I can change it out once track season starts up again, move it up to a thicker oil.
Matthew
Old 11-12-2004, 06:32 PM
The 0w40 is much better for the winter. Try pouring a bottle of it versus 15w50 when it's below freezing and you'll never use the 15w50 again in the winter. Another great alternative is a mixed fleet delvac 1 5 w 40. It exceeds all porsche specifications for oil- there's a great thread live over on rennlist discussing this exact topic.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Charles Navarro
President, LN Engineering and Bilt Racing Service
Home of Nickies, IMS Retrofit, and IMS Solution
Old 11-13-2004, 04:55 AM
The difference between M1 0/40 and 15/40 isn't that great
15/40
for cold weather use the # to look at is pour point both are -45&deg C, if it ever gets that cold you have a bigger problem than oil.
911 engines were not designed for light weight oil like the newer cars. Back in the old days straight 30 was used all year round.
Bill Verburg
Old 11-13-2004, 06:48 AM
rhk109's Avatar
I was under the impression that specific areas of our air cooled engines get really hot. In the winter those few areas that get really hot may not be enough to bring the whole 12 quarts of oil up to a high temp, but I assume those really hot areas still need the protection of a heavy weight oil. For this reason I am hesitant to switch away from my valvoline racing 20W50 in the winter. Any thoughts?
rhk109
'76 911 3.0 Webers
Old 11-13-2004, 09:12 AM
