disband
lug nut material
are the aluminum OEM lug nuts for weight savings, or to keep a "soft" lug nut against the fuch's aluminum construction? would a steel lug nut over time damage the rim? assuming that they are installed with care, and only tightened to spec.
tia
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Original reason was for weight savings...when Porsche was seriously interested in this.
There are VW transporter steel lug nuts that many use for track use or DE days. Make sure you lube up the dome contact surface. Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
disband
when you say transporter, do you mean a VW bus?
as always, thank you wil for a quick response.
yes. Use Optimolly on the surfaces. search for info on this
14mm or 14.5mm I cant remember.....
Thanks Todd I drank what? = Party out of bounds - PriceLESS - BudWIZER "Boy Im gonna burn you a new one! - A new what officer?" = night in jail 993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
doozer....what are you asking?
The thread on the lug studs is 14mm x 1.5 pitch. The lug nuts can't be purchased off the rack because ( if Fuchs are used) the mating surface of the lug nut must perfectly fit the hemispherically-shaped hole of the Fuchs wheel. Therefore the need for the $1-2 steel lug nut from the VW dealer, or such. Wil
MBruns for President
I bought some off ebay that I use for the track. around $30 After seeing part of the threads left on my hubs I feel much safer track driving with steel lugs
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Will,
I just could not remember the correct stud mm. I knew it was either 14 or 14.5mm Thanks.
some track require steel lug nuts. For street driving, I use new AL lug nuts because it looks nice.
1984 911 Euro Cabriolet 1988 928 S4 with Murf Supercharger S1 |
HEre's a cosmetic question: Has anyone seen the "black nickel" lug nuts that Perf. is selling? If so, what do they look like?
disband
http://www.pelicanparts.com/catalog/shopcart/356M/POR_356M_suspen_pg2.htm#item10
like these 356 lugs?
I can't say fior sure if the 356 parts are the same....I know these parts as a VW transporter part number. I f I find the number...I'll post it here. Maybe pelican tech staff can physically match up the 356 piece with a normal aluminum ( or is that aluminium...as the Brits say) piece.
Wil
Steel lug nuts should be available from the dealer. They were used on early 911s with steel wheels. Not sure about the 356 lug nuts, but I suspect they would be no different.
Sherwood |
Or, rather than buying from the dealer, you could buy them from our host.
Steel lug nut: N-020-112-1 $1.30 each
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
disband
i did get them from here, the 356 units listed above. when i went to check out it did list the applications and it stated 911,914, and 356.
the vw dealer wanted like $5 each, and an after market vw place here in the south bay called bugformance wanted $2.80, so the pelican purchase was the deal. john, did you find that in the 911 section of the catalog?
