-   -   * BIG off at the track - and a torque tip - (http://forums.pelicanparts.com/porsche-911-technical-forum/191992-big-off-track-torque-tip.html)
Fast82930 11-13-2004 05:48 PM
Craig,
I checked mine today and they are installed correctly with the nut/threads down........
Mike Feinstein 11-13-2004 05:55 PM
It's one thing to lose it because you overcooked a corner, missed an apex, or did something else becuase of fatigue (mental...not metal). At least you can study the situation and learn from your mistake. It's quite another when it's something completely out of your control.
Glad that the damage was minimal. You're a lucky man!
Chuck Moreland 11-13-2004 06:00 PM
I think the upside down installation may have accelerated the failure. But that bolt is supposed to be working in pure tensile so it shouldn't matter which way the threads were oriented.
That 7/16 bolt is only about 11mm. That is undersized for the added leverage created by the spacer IMHO. The factory design has a much greater safety factor.
I think the bolt was loose as someone above said. But it may have become loose due to stretch (a result of undersize bolt and added leverage). Once loose it was just a matter of time till failure.
jfpound 11-13-2004 10:13 PM
That's what I was going to say... if the bolt lost it's preload, that's when the fatigue would have been the fastest
Jack Gresham 11-14-2004 06:55 AM
What do you guys think about changing those bolts at half the life time experienced before the failure ?
Tricky D 11-14-2004 07:42 AM
Craig,
Have you notified ERP of this failure of one of their components?
Perhaps they would look into a redesign.
Craig 930 RS 11-14-2004 08:44 AM
Exactly. I am working on it - I have a contact for Eisenlohr.
geof33 11-14-2004 12:31 PM
Not arguing here, just looking at things and asking questions...
It seems the upside down installation would be the biggest culprit. It seems the pivoting tie rod around the bolt would lessen the overall force on the bolt making it less likely to fail if installed correctly. However, the sheer forces on the top of the bolt would seem to be higher. Given the fact that a cut thread is weaker anyway, it makes sense that it fractured the way it did.
Here is the question of for the rest of us... Is the bump steer setup ultimately unsafe in the long haul, especially under high load? Or, did the reversal of the bolt cause a somewhat extreme example of a BIG oops?
Do we all go out and check our bolts for fatique/cracking? It would suck to have that happen at ANY time, much less under high load/speed situations...
Craig 930 RS 11-14-2004 12:36 PM
I too think the upside down boof was the culprit - & the threads are mashed from the strut arm contact.
Come Monday or so I need to 'go have a chat'http://www.pelicanparts.com/support/smileys/chix.gif
Craig 930 RS 11-14-2004 12:42 PM
Looks like I ought to replace the OTHER SIDE bolt too - it surely has been compromised. And gets higher loads at the Seattle area PRI track (many left turns)
Tricky D 11-14-2004 01:07 PM
Yes, Craig, you should replace the other one. You got lucky once - don't push it.
jfpound 11-14-2004 06:08 PM
I'd say, if the a bolt being upside down could cause the steering to fail, the design is too weak to start with.
richard glickel 11-14-2004 06:59 PM
Glad to see that you're okay and the SC is very repairable.
I noticed that you had recently gone to JRZ shocks. Was something not put back together properly after installation of the shocks?
All the best.
Richard
don911 11-15-2004 05:06 AM
Craig,
Sorry about the off. Glad you're ok and not too much damage to your car.
Good luck with your "chat". :)
Jeff Alton 11-15-2004 12:56 PM
Craig, glad you are okay. I am interested to see how things turn out when you talk to the shop that installed them. Turn 9 is not where I would want to have problems like you had!!!! Better there than going into turn 1 I guess.
Jeff
KobaltBlau 11-15-2004 01:10 PM
are there any markings on the head of the bolt (like ridges from the center to one of the points)? a photo would be good.
http://www.americanfastener.com/techref/grade.htm
Tyson Schmidt 11-15-2004 01:31 PM
http://forums.pelicanparts.com/uploa...1100554125.jpg
Above is what you need to do when using very long bump-steer drop-links. This is a drop-link that has been gusseted to the steering arm, but later removed to change sizes. It shows the bracing. This keeps from introducing too much flex on the long through-bolt.
Az911 11-15-2004 01:37 PM
Tyson or anyone what ride height would require a bump street kit like that?
KobaltBlau 11-15-2004 01:41 PM
I like that, Tyson.
Craig 930 RS 11-15-2004 01:46 PM
Here is the bolt head - nothing - no markings. Make any sense?
http://forums.pelicanparts.com/uploa...1100555023.jpg
Here is a new bump steer assy - same bolt, btw:
http://forums.pelicanparts.com/uploa...1100555102.jpg
