* UPDATE --- BIG off at the track - and a torque tip -
Had the bolt which goes through the ERP bump steer setup break.
In a BIG way. http://forums.pelicanparts.com/uploa...1100236590.jpg Going through turn 9 (at Pacific Raceways in WA State) Approx 90 mph and at full throttle the right (relatively unloaded) bump steer bolt broke -- quite possibly due to overtorquing. Mid corner the steering got lighter - and the car just went straight. Very little control. Just tried to keep it straight. Right through the gravel, like a shot. Bounding, bouncing, ripping and scratching at the underside of the car until the left side caught and spun me around in a 360. Heading towards the wall, both feet in. Point of breakage was way up the track in the pic below. I ended up where I took the picture below. http://forums.pelicanparts.com/uploa...1100236637.jpg I have never seen a car spin in this corner and NOT hit the wall. Many have been a total with at least some injuries. In the words of the track event chief: "You need to go buy a lottery ticket tonight" ----------------------------------------------------------------- Probable cause? Over torque of the bump steer bolt. A metallurgist who was driving at the track said that the bolt had been fractured for quite some time - and that the portion holding it together consisted of only the center 1/4 of the bolt. http://forums.pelicanparts.com/uploa...1100281672.jpg She went home in a friends' trailer. http://forums.pelicanparts.com/uploa...1100236785.jpg Got to drive his 440hp 930 - on Hooisers - home http://forums.pelicanparts.com/uploa...1100282064.jpg Very lucky. Watch that bolt torque! |
Craig
Glad to see you are ok. Loosing steering on the front straight nerve wrecking. I have seen 2 cars hit the walls there. alf |
Scary.
In pic 1 it looks like the bolt sheared at both ends. It looks like there is a stub remaining in the tie rod, and obviously another holding the nut to the steering knuckle. Why do you think it was over-torqued? Did you do the installation? |
"Why do you think it was over-torqued? Did you do the installation?"
It only fractured at one point. The 1st pic is of the 1/2 bolt still in the strut. Hammered it out. A metallurgist who was driving at the track said that the bolt had been fractured for quite some time - and that the portion holding it together consisted of only the center 1/4 of the bolt. The early fracture points had grease and dirt on them - it was evident even to me that it had been that way for some time. I didn't do the installation. --------------------------------------------------------------- It was scary. Had no options, very little control. Car ran wide by itself, I took a mental inventory of what my sensory inputs were telling me -- and nothing made sense. Equipment failure is one variable that makes it the scariest of all. WTF? just about describes what goes through your mind |
Okay, but why does that imply overtorque? The origianl fracture may have happened from impact, hitting bumps, overstress, etc. It's not unusual for a crack to develop and grow over time, eventually leading to failure.
That ERP bolt is a problem waiting to happen, anyway.
Mounted in single shear like that? Gotta be a way to wrap around the steering arm in double shear. |
To the metallurgist, it had all signs of overtorquing.
He is the expert, I am not - |
Enough of a reason to avoid that system. I have never heard of the factory ball joints failing.
"That ERP bolt is a problem waiting to happen, anyway.
Mounted in single shear like that? Gotta be a way to wrap around the steering arm in double shear" Our thoughts (track guys that is) exactly. I thought the ERP stuff was beyond reproach and I honestly haven't heard of another failure like this. But, the design makes little sense - huge side forces acting upon the bolt. Any other options?? |
Were you having a problem with the stock setup? My car is pretty low, see's mostly track, and I can't say I've had any issues with the steering, or bump steering effect. Maybe the simpliest solution is nothing.
I can't bend the arm, it's against our race rules.
If you bend the arm, like the 935 (so I'm told) you shorten the arm, which tends to increase the steering ratio. Metallurgical issues with that also. My car is as low as it will go, and the steering is very difficult at high speeds and high g's. The steering forces are very high. Bump-steer is also pretty significant, particularly in places like the apex of the downhill at Lime Rock. Lots of apexes seem to have a wowie in them, I have noticed, that upsets the car just at the point of max lat. |
I installed the ERP BS kit back in 1999 - one of the first things I did after buying the 911 was lowering & corner balancing -- and consequently adding the BS kit.
I looked at the fracture closely just now - and IMO I am certain it isn't from overtorquing. Very unlikely. Your opinion? http://forums.pelicanparts.com/uploa...1100298390.jpg |
I'm no metalurgist. But that looks like it was worked back an forth, leading to fatigue.
Am I seeing that right? It looks like the area that just failed is a rectangle in the center of the bolt? I need a closer shot. It looks like there was a crack on either side of the fracture. Overtorquing causes the bolt to yield and thus reduces it's fatigue life and ultimate strength. That could have been what started the problem. Though I don't like the long bolt bump steer solution either.
How does the other side look?
Tom |
Haven't checked the other side - my confidence level in this setup is LOW right now.
Chuck...........WHAT HAVE YOU GOT PLANNED? |
| All times are GMT -8. The time now is 07:22 AM. |
