Vibration when hard on brakes
This has happen few times, yesterday it was pretty bad. I took a friend for a ride, got going pretty fast and hit the brakes hard and a vibration / grinding (not so much grinding) noise was heard from the front end
I let up off the brakes and reapply and it's less. Under normal braking it seems to be fine. Any thoughts I'm going to take a look this weekend.
Rob, 88 911 Turbo |
Sounds like either a warped rotor or worn suspension bushings. Neither problem is safe to drive with. Drive slowly to a good shop or fix them soon.
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
MBruns for President
Or a loose caliper. slow down until you can check it out
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Designer King
As above, or maybe you are down to the wear limit on your rotors or pads = time to replace.
Or, if you don't drive much, it might just be rust on the rotors. Check also your wheel bearings & suspension.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Sounds like warped rotors and/or worn pads.
1984 Targa |
Infuences on brake judder:
* worn bearings *worn struts * disk quality, tolerances on the dimensions, material specifications, casting and residual stresses. * Quality of the pads, the higher friction coefficient makes the car more judder sensitive. * Some pad/disk combination can create friction material debris on the disk, this can also create judder. * Disk and caliper aligning, the disc should not have more axial play as 0.1 mm. * Larger wheels (heavy) increase the judder sensitivity. * The lighter caliper makes the car more judder sensitive. * The resonance frequency of the suspension/wheel layout is a great factor in judder sensitivity. * Changing to larger/smaller Calipers, sometimes Spacers and longer Studs are needed to change the above characteristics. Of course if you stay w/ stock brakes Porsche has already done the hard work
REad this: No such thing as a warped rotor apparently
http://www.stoptech.com/whitepapers/warped_rotors_myth.htm But regardless, yes, that is the problem. Replace the discs and pads... |
Thanks for all the response. I decided to replace rotors and pad, rotors did look at bit worn and groved.
Checked bearings all looked good, cleaned, repacked and reinstalled. I did see on drivers side the tire has been rubbing a bit on the washer fluid tank and top corner of front bumper. I do have 18" rims, a little tight. Thanks again
Rob, 88 911 Turbo |
Here is another cool brake picture.
Rob, 88 911 Turbo |
Does anyone know how tight the nut under the hub dust cap( the nut with the 6mm allen bolt)? I thought I read 11 ft lb. but I dont have a tool or better said don't know how I would measure the the torque value for this. Sorry if this is a little confusing.
Rob, 88 911 Turbo |
I ask because the whole hub / rotor assemble spins nice and smooth but seems a little tight. It spins but lows fast?
Rob, 88 911 Turbo |
